Old 10-03-2010, 08:13 AM   #1
Primer on drywall
should you put primer on drywall, and if you can what would make the primer not adhere to the wall. when i went to tap the celling the primer came off with the tape. I used blue tape.
kaytaycourtney is offline   Reply With Quote
Old 10-03-2010, 07:29 PM   #2
Primer on drywall
tape is too sticky or the primer hasn't completely cured. remedy: less sticky tape or a longer dry time
racebum is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
New drywall -Sherwin Williams Primer n0c7 Painting 11 12-22-2011 01:27 PM
primer lifts a bit of drywall mud rtoni Building & Construction 0 04-16-2010 04:36 PM
primer not adhering to drywall texture? eli_carson Drywall & Plaster 10 08-18-2009 02:46 PM
Sanding drywall primer and a few crack repairs n0c7 Drywall & Plaster 4 06-09-2008 03:31 AM
