Old 07-10-2006, 01:25 PM   #1
primer drying too fast
I started to prime new wood moulding this morning and it's drying way too fast to work with. It's hot and a little humid today so I'm sure that's the problem. I'm using kilz oil based stain blocker primer. Would a little mineral spirits help extend the wet edge time? thanks
farrington135 is offline   Reply With Quote
Old 07-10-2006, 08:53 PM   #2
How hot/humid is it?
I would wait for a cooler day.
If you dilute the paint then your results may suffer.
redline is offline   Reply With Quote
Old 07-10-2006, 10:19 PM   #3
Try using Penatrol. It is an alkyd base paint extender or go to a long-oil (slow drying) undercoating primer.
Kennedy is offline   Reply With Quote
Old 07-18-2006, 06:16 PM   #4
SgtBaldy's Avatar
Thinning primer is a no-no. Never tied penatrol in primer but I would run that by manufacturer first. Works great in alkyd enamels though.
Why do you need a wet edge on your primer for, isn't it going to be sanded after?
SgtBaldy is offline   Reply With Quote
old primer firsthomegal Painting 2 06-21-2007 09:28 PM
Primer for MDF? NateHanson Painting 13 05-09-2007 10:09 PM
Oil primer not drying? Tmb9862 Painting 2 10-31-2006 10:25 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
Please tell me this primer is going to dry!! Autumnknight Painting 6 09-20-2006 08:22 PM
