Primer As Ceiling Paint - Painting - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 08:39 PM   #1
Primer as ceiling paint
I hired a contractor to scrape and redo my popcorn ceilings throughout my condo. He said he would use a knockdown texture and use primer to save me money. While it looks ok in most areas, I am concerned this is what he did in the bathroom above the shower area. Should I pain the ceiling in my bathroom to protect it from moisture damage? The appearance is a flat finish. This was my first experience with a contractor and wish now I had asked more questions!
newbie40 is offline   Reply With Quote
Old 12-29-2010, 09:18 AM   #2
Faron79's Avatar
Rewards Points: 260
Depends on you expectations of performance....
PRIMERS are for adhesion...some have stain-blocking properties as well.
>>> This is a case where "saving money" will COST you money, in the form of long-run water-damage in that bathroom!
BUT....for washability and moisture-resistance, they score a ZERO.
Get some actual paint on there...ESPECIALLY in the bathroom. There, I would use an Eggshell sheen for better moisture holdout. Flat ceiling-paint is fine everywhere else.
Faron
Faron79 is offline   Reply With Quote
Old 12-29-2010, 11:34 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
Primer is really no good for a finish coat. It tends to be very pourous which is great for top coat adhesion but will attract all kinds of dust and dirt and really won't protect your surface.
Old 12-29-2010, 11:58 AM   #4
Gymschu's Avatar
Rewards Points: 1,014
I'm just trying to figure out how he is saving you money. Sure, primer is a few bucks per gallon cheaper than flat paint or even satin paint, but what's a few bucks if you don't get the job done right? I could MAYBE see the savings being a factor if it saves you $300 or $400, but, to me you're maybe saving $40 or $50 at the most.
Old 12-29-2010, 02:32 PM   #5
40+yrs Paint Trades
The guys a scab. Fire him and hire a real painter.
Eggshell or satin in the baths, flat white everywhere else.
hoz49 is offline   Reply With Quote
Old 12-30-2010, 10:35 AM   #6
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
semi gloss in the bathrooms is way better then any satin paint. bathrooms contain high humidity if there is a shower. If there is no shower then satin would work.
Primer is just a cheaper coat of paint. He isnt saving you money, he is saving himself money. Next time you get a bid you should ask for specifics.
stoner529 is offline   Reply With Quote
Old 12-30-2010, 03:24 PM   #7
40+yrs Paint Trades
Maybe the guy doesn't want the "institutional look' that semi gloss gives. My bath is painted satin about 10 years ago. I shower in there daily. The paint look fresh, white and new as the day I painted it.
I try not to let theory get in the way of practice.
Old 12-30-2010, 03:51 PM   #8
stoner529's Avatar
Rewards Points: 154
It really is just an issue of keeping moisture out. semi gloss repels the water better as you already know.
Old 12-31-2010, 02:52 PM   #9
It also depends on the brand. Some Satin's like from Sherwin Williams have a lot more shine than others. I have a flat paint on my batroom ceiling and 10 years later it is just about due for another coat.
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 09:06 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
