#1 |
Primer for Cabinets
I am getting ready to paint my Cabinets. The are an unfinished Alder and I was wondering which type of primer I should use on them prior to painting. I didn't know if there was anything special that I needed to use or not. Thanks!
#2 |
Primer for Cabinets
You probably want a sealer/primer combination. I would use a sandable one. Apply the sealer/primer. Let it dry. Then sand lightly before your finish coats.
If you have patience. A mix of 50 percent mineral spirits and 50 percent processed (not raw) lindseed oil is an old time favorite sealer for raw wood. Follow it with an alkyd primer/underlay product. Finish with either acrylic/latex or oil enamel. Paint store, not box store crap right? |
#3 |
Primer for Cabinets
I'm going to Sherwin Williams, does that qualify as a paint store? I will probably just do the primer/sealer prior to painting. Thanks for you help!
#4 |
Windy Painters
Primer for Cabinets
I preffer BIN Shellac primer. Dries in 30 minutes. Covers all stains and fills wood knots. It's a little pricey - 40$/g but it's worh the money. Usually I apply with Fraco 495.
Chicago painter Cabinets refinishing |
#5 |
Rubbin walls since'79
Primer for Cabinets
There is an oil primer called underbody that is made for raw wood. The standard for years. Seals, and then sands smooth.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS |
| The Following User Says Thank You to Brushjockey For This Useful Post: | chrisn (10-31-2011) |
#6 |
Primer for Cabinets
How do you keep the Bin shellac from drying up as it comes out of the tip (5/17)of the airless?
#7 |
jschaben
Primer for Cabinets
My cabinets are pine and mdf and I was using bin but for the $20/gal difference, I've found cover stain just as effective. The pine is pretty well knot free but I do spot prime knots fingernail size and larger with BIN.
John Schaben "Where all think alike, no one is thinking very much" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 |
Primer for Cabinets
The benefit of using bin, even on clear pine, is that knots are not the only tannin issue. You can get tannin bleed in the form of haze, a general yellow/brownish discoloration, which I've been seeing more frequently lately.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#9 | |
jschaben
Primer for CabinetsQuote:
Patience I guess A Ben Moore guy suggested I do that... hmm,, musta been 15 years ago.... for a job I was contemplating. But he also suggested that by going that route it would need 4 to 6 weeks before topcoating.
#10 |
jschaben
Primer for Cabinets
Bin sprays pretty well. I haven't used it with anything as big as a 495 but have sprayed it with HVLP and wagner buzz bombs. I like the HVLP best, just like from a rattle can but a lot cheaper.
#11 | |
jschaben
#12 |
Primer for Cabinets
With latex, sometimes before the paint dries
#13 |
jschaben
Primer for Cabinets
That's what I was thinking. Sorta like those felt tip markers.. Had one of those took two coats of BIN to block.
| Display Modes | |
| Zinsser Bathroom Paint | canuckjack | Painting | 7 | 08-27-2012 09:00 AM |
| Free 5 gl of Behr Primer: Why Shouldn't I use it? | Lovegasoline | Painting | 15 | 03-24-2011 11:20 AM |
| Issues with primer on kitchen cabinets | blinkandimgone | Painting | 4 | 08-17-2010 12:48 PM |
| Primer for vinyl covered wallboard | a new DIY-er | Painting | 0 | 02-20-2010 07:29 AM |
| help me pick a primer | jheavner | Painting | 21 | 01-27-2009 12:30 AM |
