Primer For Baseboards - Painting - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 11:57 AM   #1
Rewards Points: 160
Primer for baseboards
I have brown wood baseboards that are currently stained...I will sand, prime and paint then white.
Thing is...since its wood do I prime with oil based primer then paint with latex?
hellothere123 is offline   Reply With Quote
Old 04-18-2009, 04:01 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Yes, use oil based primer. The stain in the wood as well as the tannins in the wood will bleed right through a latex primer.
Old 04-18-2009, 09:47 PM   #3
Rewards Points: 160
Thank you
I've read different opinions...but oil based makes more sense
Old 04-19-2009, 04:02 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
You are here asking for advise and then recommending painting new drywall without priming?
Please do not answer a question unless you actually know the proper answer, it is confusing to the DIY
chrisn is online now   Reply With Quote
Old 04-19-2009, 08:50 PM   #5
chrisn- the question was about painting a previously stained baseboard- not drywall!
sagechickie is offline   Reply With Quote
Old 04-20-2009, 04:35 AM   #6
chrisn's Avatar
Rewards Points: 504
Please read post below, that is what I was referring too.
BM Super Hide Primer ?
Old 04-20-2009, 05:47 PM   #7
Rewards Points: 77
I just completed one of my romms in my new home and used latex kilz and then semi gloss trim and had no problems at all.
bowanna03 is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
Best primer for bathroom ceiling dbldee20 Painting 11 01-06-2009 03:25 PM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 08:13 PM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 04:32 PM
