Primer Bad Results Over Repaired Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 01-11-2013, 09:29 PM   #1
Primer bad results over repaired drywall
After priming my ceiling with Sw drywall primer, the areas that had drywall repairs show some differences. (By touch, they're hardly felt) I thought the repairs were sanded properly... Will a top coat cover these differences, or do I need to sand these?
Adrenalinejunky is offline   Reply With Quote
Old 01-11-2013, 09:37 PM   #2
Rewards Points: 13,300
If they can not be felt the top coat should cover it.
PS It's going to need two top coats.
Adrenalinejunky (01-11-2013)
Old 01-12-2013, 05:47 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
[QUOTE=joecaption;1091385]If they can not be felt the top coat should cover it.
PS It's going to need two top coats.[/QUOTE]
Great balls of fire, he actually got something right!:laugh ing:
Old 01-12-2013, 06:25 AM   #4
[QUOTE=chrisn;1091542]
I wouldn't go that far. Just because it doesn't have an edge doesn't mean it won't look like a sunnyside egg on a fastener hole or a hump/mound on a tape seam. The touch does not have the same precision or sensitivity as a ray of light. Let's not get ahead of ourselves here.
Old 01-12-2013, 07:50 AM   #5
chrisn's Avatar
Rewards Points: 232
[QUOTE=jsheridan;1091553]
I did highlight in red the pertinent part.
Old 01-12-2013, 09:01 AM   #6
[QUOTE=chrisn;1091572]
My bad. I was too eager.
What grit/tool to use to sand drywall AFTER primer shelzmike Painting 9 02-27-2012 09:44 AM
Drywall primer white29 Drywall & Plaster 1 08-22-2011 04:26 PM
primer lifts a bit of drywall mud rtoni Building & Construction 0 04-16-2010 04:36 PM
Using new Behr Paint & Primer in One...will report back with results BigMatty Painting 2 06-23-2009 10:43 AM
Primer Over Drywall dgoldb1 Painting 16 03-03-2008 05:37 PM
