Primer With Adhesion For 140 Year Old Boards With Knots. - Painting - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 08:52 AM   #1
Primer with adhesion for 140 year old boards with knots.
Hello--I am painting a newly sanded pine floor which is 140 years old. My question is, do I need to worry about the knots bleeding, or can I assume the wood has stabilized. Also, if I use BIN which is shellac based will it offer the same adhesion to the wood as oil? This is preferable since it's a floor.
Thanks.
chuckc is offline   Reply With Quote
Old 07-16-2012, 10:31 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
I would "Paint" the floor as a last option and look more into stain & poly. What does the floor look like now?
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-16-2012, 10:45 AM   #3
Rewards Points: 14,026
Why in the world would you ever want to paint it?
Plan on having to go back every year and sand and paint agian in any trafic areas.
Old 07-16-2012, 11:32 AM   #4
Rewards Points: 290
I have had painted floors in my previous home. Wasn't pine flooring though. Hardwood flooring in industrial white in a farmhouse style....wear rating was pretty good.
I think the issue that others have not alluded to is the fact that pine is just ~soft~
mobiledynamics is offline   Reply With Quote
Old 07-16-2012, 03:20 PM   #5
Too Short? Cut it Again!
Modern quality floor paints like Benjamin Moore's Porch, Floor and Patio have oil based finishes with urethane reinforcement and acrylic ones with epoxy. They will hold up as well as clear poly with urethane. The acrylic paint has a bit less sheen to it.
Primers are generally not recommended for floors.
In answer to your question. The knots should have aged so they don't bleed but you can hit them with shellac if you want to be sure. BIN will work too but I think is overkill for this.
Original Fascia boards need to be replaced brickhaus Roofing/Siding 3 08-25-2010 10:10 AM
Latex over alkyd primer TVC15 Painting 15 08-14-2010 11:42 PM
Best primer for preventing wood knots from bleeding through? SandyK Painting 15 02-26-2009 09:25 AM
Painting over 4 year old primer coat flyfisherman Painting 5 01-06-2009 06:51 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
