Primer - Painting - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 05:15 PM   #1
Primer
Good evening,
What is the purpose of priming before painting interior rooms?
Should surfaces that have been painted before be primed?
Should surfaces that were covered with wallpaper be primed?
Are there quality differences between different primers? What is a good brand?
wriegler is offline   Reply With Quote
Old 10-30-2010, 05:29 PM   #2
Rewards Points: 526
The main purposes of priming is to create a bridge between uncomplimentary coatings and to promote adhesion. SOme people believe priming also aids in coverage and texture, but I personally don't put much stock in that.
You DEFINITELY want to prime after removing wall paper.
There are seemingly as many varieties of primer as there are paints. Everyone has their favorites. General rule of thumb is that quality paint brands often have quality primers too.
Windows is offline   Reply With Quote
Old 10-31-2010, 04:21 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
There is the answer to those questions!
Old 10-31-2010, 08:47 AM   #4
ccarlisle's Avatar
I think there is a general guideline that goes something like this: you prime new materials but do not prime painted surfaces. So you would prime new plaster, or new wood - but not a painted wall.
You paint over a painted wall, most times. Of course there are exceptions but those are the main ideas.
Primers are loaded with inorganic fillers in order to provide a uniform surface upon which to apply a paint. Paints on the other hand have more pigments and resin and are intended to sit on top of a smooth surface.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 11-01-2010, 03:29 PM   #5
Handyman
Rewards Points: 512
LOL..
Paint without primer...the answer will soon be obvious
canadaclub is offline   Reply With Quote
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 11:48 AM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 06:29 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
