Primer - Painting - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 06:07 PM   #1
Rewards Points: 290
Primer
What's your primer of choice these days.
Have always used PPG 624 and zinnsers red can on problamatic areas.
mobiledynamics is offline   Reply With Quote
Old 11-03-2011, 06:23 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
I carry about 5 primers- for different problems.
Question is to general.
Primers are problem solvers- whats your problem?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-03-2011, 07:25 PM   #3
Rewards Points: 290
Need 2 Primer recommendations.
New Sheetrock/mud.
Primer for that.
I also have a brand new cast iron pipe / no hub fittings.
I plan to paint that.
I'm going to assume Zinnsers red is the best primer for this.
Old 11-03-2011, 07:59 PM   #4
Gymschu's Avatar
Rewards Points: 930
For new drywall, I'm not too fussy. Been doing the painting gig for 35 years and never had a paint failure because of the primer I used. My preference is SW's Drywall Primer, but, it can be pricey. I like Valspar's PVA primer but many painters on here will say NO to PVA. I also liked Valspar's "New Contruction Primer" but I believe it has been renamed.......it was a lot like Sheetrock's First coat. For metal, I like an oil based primer formulated for metal.......most major brands make a primer for this purpose.
Old 11-04-2011, 05:28 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 474
New Sheetrock/mud.
Primer for that.
what is this?
Old 11-04-2011, 06:03 PM   #6
Too Short? Cut it Again!
I use a high bond waterbased primer and 12 inch brush to prime by truck before it goes to the body shop and all my cast iron pipes?
What are you priming? This post is idiotic.
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 11:48 AM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 06:29 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
