Primer - Painting - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 04:31 AM   #1
primer
what color primer do i use under antique silver ( very light gray) by glidden
msannie63 is offline   Reply With Quote
Old 09-16-2011, 07:44 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
First question is what are you painting so we can help you get the right primer.
Most primers can have a little black or burnt umber (Black for a bluer grey- B Umber for a browner grey) added.
Also Glidden makes a primer called Gripper that comes in a med grey. It is pretty good for adhesion.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-16-2011, 04:46 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
white?
chrisn is online now   Reply With Quote
Old 09-16-2011, 09:46 PM   #4
Gymschu's Avatar
Rewards Points: 842
Doesn't really matter if you're applying two coats. Light gray will cover white primer in 2 coats. If you're trying to avoid doing 2 coats, you could have the primer tinted to a very light gray. That is all.
Old 09-17-2011, 06:16 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
And if what you are painting has already been painted you probably don't even need primer.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 11:48 AM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 06:29 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
