Primed Walls - Painting - DIY Chatroom Home Improvement Forum
Old 12-29-2013, 06:01 PM   #1
Rewards Points: 874
We have been priming(with zinzer123) all afternoon. It seems to be going well but there are some areas where you can see a little bit of the drywall and some of the joint lines. Is this normal? Will 2 coats of paint cover it? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 12-29-2013, 06:08 PM   #2
Rewards Points: 13,450
Looks normal to me.
Now the time to fix any flaws that show up.
Paints not going to fix them.
Mstrlucky74 (12-29-2013)
Old 12-30-2013, 03:19 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 308
To answer your questions, yes and yes
chrisn is online now   Reply With Quote
Old 12-30-2013, 03:54 AM   #4
Rewards Points: 4,796
If you're seeing the color only show through, then yes paint will cover it. If you're seeing ridges where the compound wasn't feathered or sanded well, then no.
jeffnc is offline   Reply With Quote
Old 12-30-2013, 06:17 AM   #5
Rewards Points: 874
Thanks guys . So the few areas where it wa not feathered great(only 1 or 2 small places) what grit paper should I use to start? 100??
Old 12-30-2013, 06:35 AM   #6
I'd be using a med. sanding sponge or screen cloth not sand paper.
Sand papers going to just load up and leave scratches.
Sand in a ciruler motion.
Low areas get sanded, highs get sanded.
Thin the mud and use a wide knife.
Reprime any touch ups.
Old 12-30-2013, 07:11 AM   #7
Rewards Points: 5,974
I think Joe meant low places get filled high places get sanded.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (12-30-2013)
Old 12-30-2013, 01:32 PM   #8
120 to 150 for final sanding, 100 and lower can show swirl marks that might show through the finish. A sanding screen works good, but so do the sanding sponges (I don't mean the wet kind, I'm not very familiar with those).
Old 12-30-2013, 04:29 PM   #9
Rewards Points: 874
So after I sand down I need to put mud on ??? I can't just prime?
Old 12-30-2013, 04:41 PM   #10
Jmayspaint's Avatar
Rewards Points: 534
I think it's just being pointed out that now is the time to fix any imperfections.
Your ready to sand and paint
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Mstrlucky74 (12-30-2013)
Looking for confirmation these walls are not load-bearing walls jmai14 Remodeling 2 11-09-2013 09:28 PM
2x4 cabin, what can these walls handle? Ilyae Building & Construction 8 04-08-2013 11:02 AM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 09:20 AM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
