Primed Patches Shiny After Paint--how To Fix? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 12-31-2016, 11:09 AM   #16
Jmayspaint's Avatar
Rewards Points: 536
Re: Primed patches shiny after paint--how to fix?
Originally Posted by chrisn View Post
It will seal it up tight. You would be better off priming the whole wall with it.
Yeah, spot priming with Gardz would certainly make the problem worse.
If you Really don't want to prime the whole wall then I would either use the paint itself as has been mentioned (though I hesitate to do that with a paint like Cashmere that isn't rated to be applied directly to joint compound) or use a low sealing drywall primer. The cheaper the better in this case. That'll prime the patches while still leaving them porous.
Something like this perhaps;
http://www.valsparpaint.com/export/d...all_Primer.pdf
Generally when you see language like this in a primers description;
"Valspar Interior Latex Drywall Primer is specifically designed to equalize surface texture differences between sanded tape joints and new drywall, resulting in an extremely uniform finish coat appearance."
That's a primer that isn't designed to seal well, but rather equalizes the surface by creating uniform porosity. It will lower the sheen of an applied finish rather than increasing it which is what caused your shiny spots.
Jmayspaint is online now   Reply With Quote
Old 12-31-2016, 12:25 PM   #17
Anonymous Tard
getrex's Avatar
Rewards Points: 16
We've done it many times without issues but I think it might be because we use 18" 3/4 naps and put on more paint. And we use Cashmere most of the time. As long as your big patches and mud spots are done on the first coat it turns out fine. But if you are using a thinner nap then you really have to prime. I've even used a spray oil primer on mud spots and that worked really well.
getrex is offline   Reply With Quote
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 05:19 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
