Prime Wallpaper - Painting - DIY Chatroom Home Improvement Forum
Old 02-10-2012, 03:12 PM   #1
prime wallpaper
What is the best product to prime over old wallpaper befor painting it. I am not going to strip the wallpaper off.
Joyce Smith is offline   Reply With Quote
Old 02-10-2012, 09:31 PM   #2
ltd
Rewards Points: 536
zinsser cover stain oil base primer ,about 22 dollars at the big box
ltd is offline   Reply With Quote
Old 02-10-2012, 09:40 PM   #3
Rewards Points: 13,960
Gee I hope some of the real that do this for a living, home remodelers chime in here on this one.
Horrible idea, Painted wall paper is next to impossible to remove.
Paint may loosen the glue.
It will look like painted wall paper.
Anyone that tells you it's a good idea would have to be DIY that's never had to deal with the after effects.
Old 02-14-2012, 03:36 PM   #4
I agree... Do yourself a favor and remove it. You'll be glad you did. Its not as bad as you think. score it with a tigar add a little fabric softener to some water and saturate fluently! Let it soak in... Make sure its very wet and scrap it off with a firm putty knife.
vicpet is offline   Reply With Quote
Old 02-14-2012, 04:38 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 474
Just do it properly and remove it
chrisn is online now   Reply With Quote
Old 02-15-2012, 01:15 PM   #6
Too Short? Cut it Again!
I have said it before. When I see painted over wallpaper I immediately start wondering what other compromises a homeowner has made. Nothing says "I don't really care about my home" more than painted over paper.
Old 02-17-2012, 07:41 PM   #7
I also remember reading somewhere (it might have been on here) that painted wallpaper can sometimes detach from the wall. The primer and paint are too heavy for the paper.
It might be more intensive, but you should most likely remove it.
Michaelpro is offline   Reply With Quote
Old 02-24-2012, 06:02 AM   #8
don't paint it
My wife hired a pro while I was way one week who did an exceptional paint job over wall paper in our bathroom, until the seams started to show. Then it was three times the work to strip and patch. DONT paint over it....money and effort down the drain. You are delaying the inevitable
Chemist1961 is offline   Reply With Quote
The Following 2 Users Say Thank You to Chemist1961 For This Useful Post:
oh'mike (02-24-2012), user1007 (02-24-2012)
Old 04-01-2012, 01:40 PM   #9
Remove! I did like two rooms, just add hot water to some dish soap spray on heavy sit for ten and strip. It's a bit messy but you will thank yourself when you see clean fresh painted walls
jojoroberts is offline   Reply With Quote
Painting over wallpaper - no other option - How to proceed kuj0317 Painting 15 07-25-2011 04:25 AM
How to prime wallpaper to paint over? lucyshouse Painting 12 06-27-2011 06:46 AM
Wallpaper removal or primer? Should I put up new wallpaper instead? Aqua Painting 1 04-06-2011 04:36 AM
Prime after wallpaper removal stevenson66 Painting 9 11-11-2010 04:57 PM
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 03:40 AM
