Prime Then Texture Or Texture Then Prime - Painting - DIY Chatroom Home Improvement Forum
Old 01-21-2009, 09:01 PM   #1
prime then texture or texture then prime
Just wondering what order to follow. New drywall application do I prime then texture or texture then prime?
thanks!
jeerme is offline   Reply With Quote
Old 01-21-2009, 11:52 PM   #2
Hi there, I have found it best to always prime before doing any texture wall or ceilings.
Its the best way to insure an even finish, remember to always prime when doing any patchwork with drywall
textured or not
Frederick j Ward is offline   Reply With Quote
Old 01-22-2009, 10:07 AM   #3
would you also then prime the texture before painting?
Old 01-22-2009, 11:25 AM   #4
Rewards Points: 506
I would
SirWired
sirwired is offline   Reply With Quote
Old 01-22-2009, 02:29 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
The best way would be to prime, texture, prime
slickshift is offline   Reply With Quote
Old 01-22-2009, 05:32 PM   #6
Rewards Points: 20
Not to highjack but has anyone ever had problems with priming and then doing a knockdown texture? I have read that if you prime the walls first and then do a knockdwon it can smear? Any truth to that? Thanks
ponch37300 is offline   Reply With Quote
Old 01-22-2009, 09:49 PM   #7
Hi, It can smear somewhat, it has to do with the how thick or thin your texture is applied, I have had some luck in the past to spray one room, wait and test a small area, knock it down and respray over again kind of a 2nd coat and blend it all in then knock it down, it has alot
to do with timing and drying conditions, but you can also spray without primer it will dry faster where it has been taped and finished. It is
always best to prime all drywll work
Old 01-22-2009, 11:45 PM   #8
Rewards Points: 260
What can happen to the texture if the drywall isn't primed first? I skipped that step and just primed the texture. I have a skip trowel texture where the entire drywall is covered in a thin layer of plaster veneer with a trowel.
bluefitness is offline   Reply With Quote
Old 01-23-2009, 09:25 AM   #9
fix it
What's the rule of thumb for a ceiling? Same way? ...knockdown, not popcorn.
detailedEye is offline   Reply With Quote
How long should I wait to paint texture? bluefitness Painting 1 12-11-2008 11:51 AM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 06:24 AM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 04:09 PM
Steps for putting texture on new drywall TNeat Remodeling 4 12-22-2007 06:39 AM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
