Prime Spruce - Stained - Painting - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 01:09 PM   #1
Can prime spruce post/columns be stained to look like cedar post?
ABarnes5 is offline   Reply With Quote
Old 07-24-2012, 07:08 PM   #2
Too Short? Cut it Again!
If these are treated you may have to wait six months. Your choice of stain will range from semi-transparent to solid. Stains are available in both water based and oil based products depending on where you are. I used to be a purist and only use oil-based for penetrating stains but the waterbased products rival them now I think.
You can get quality penetrating semi-transparent stains (Cabot and Sickkens come to mind) at your paint store, not your box store, in a variety of colors including cedar. How the color will actually look when it hits the spruce may vary from the color chart though so try a small container on a test area first.
Solid color acrylic stains (Sherwin Williams Woodscapes would be my choice) can be tinted to any color just like paint. They allow you to retain the texture of the wood grain but cover it completely with flat color. They do not require a primer.
Old 07-24-2012, 09:09 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
This was a Quality answer!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
user1007 (07-24-2012)
To prime wood door or not? Rav Painting 11 07-25-2012 05:41 PM
Pulling up tile want to change to stained concrete drkauf Flooring 1 03-19-2011 06:57 AM
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 05:09 PM
Shallow wells loses prime rosberney Plumbing 20 01-26-2010 08:56 PM
to prime or not to prime? re: metal siding... annie68164 Painting 3 05-24-2009 08:58 PM
