Prime With Roller And Spray Spec. Primer? - Painting - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 09:18 AM   #1
Rewards Points: 169
Prime with roller and spray spec. primer?
I need to buy another 18L bucket of primer. I found a bunch of stuff for $50 at a habitat for humanity store, but it stated it was for spray application (I'll be applying it with a roller). It seemed to be aimed at contractors.
Is it any different from the other stuff?
RCGA is offline   Reply With Quote
Old 05-21-2013, 11:11 AM   #2
Too Short? Cut it Again!
My guess is it might be thinned a bit or have some sort of spray conditioner in it but you should be able to roll it without problems. Just be prepared for a bit extra splitter and slow down your roller a bit.
Old 05-21-2013, 08:13 PM   #3
Rewards Points: 169
Would this product be any good as a primer?
http://min.us/lNSTIPHLBCHk3
Old 05-22-2013, 03:14 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
It IS a primer
chrisn is online now   Reply With Quote
Old 05-22-2013, 07:56 AM   #5
Rewards Points: 5,974
Guys there are products out there that can only be sprayed because they are so thick (block filler comes to mind) but there are others. If it says spray only there is a reason, at the least get the name of the product google it and find out why spray only.
Old 05-22-2013, 09:11 AM   #6
Rewards Points: 394
Most high build products (primers, interior paints, texture paints, block fillers) require spray application, as they are applied at up to 30-40 wet mils in some cases. The 6-2 is a regular interior latex primer.
Will22 is offline   Reply With Quote
Old 05-22-2013, 09:36 AM   #7
Rewards Points: 169
Would this one be better?
spray gun vs roller brush debd Painting 21 01-25-2012 05:17 PM
Paint interior with spray gun or Wagner power roller or other? AliceT24 Painting 4 02-18-2011 01:26 PM
clean up of roller spray on new laminate Aaroncarpet Painting 6 08-30-2010 11:28 AM
Spray Gun or Roller Dinggus Painting 15 07-30-2010 11:33 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
