Prime Or Paint ? - Painting - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 09:25 AM   #1
Rewards Points: 226
prime or paint ?
my house is white (i HATE white houses). i put in new windows of different size. to fill the gaps i put some boards in, they are brown. i am going to do new siding, but not for a year or two. so i think i will paint the brown boards to make the house look more uniform, untill the siding. would it be ok to use paint ? if i need to prime (i'm pretty much sure you are going to say so), can i just use primer and not paint ? i am not worried about perfection. i just don't want what i put on to come off. though i wouldn't mind touching up now&then. i did paint one window boards, and it seems to be holding up ok.
also. if i use primer, i may have a need for the leftovers at a later date. but idk if i will ever have a need for the left over white paint.
Fix'n it is online now   Reply With Quote
Old 06-01-2013, 10:55 AM   #2
cdaniels's Avatar
You said the boards are brown, are they already painted?If they are painted brown go ahead and put a couple coats of paint on them and call it a day.You don't need to prime already painted wood.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following 2 Users Say Thank You to cdaniels For This Useful Post:
Gymschu (06-15-2013), ToolSeeker (06-01-2013)
Old 06-01-2013, 11:25 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
Agreed. If they are really glossy you could scuff them with some sand paper.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-01-2013, 11:55 AM   #4
Too Short? Cut it Again!
A nice solid stain like SW Woodscapes acrylic will go over bare or painted wood and you can tint it any color. Obviously it has different qualities than primer and paint but it requires no primer.
I think you would probably need a primer over any repairs in your situation if you approached this with primer and paint. Is the siding all painted now or is some semi-solid or solid stained.
And it is wood or a wood composite of some kind? You might experience problems if there is an oil based product on the brown boards now that you would need either a high bond latex/acrylic primer or an alkyd so paint had something to stick too.
I happen to think Woodscapes is great stuff and worth looking into for this. Arborcoat is the Ben Moore equivalent.
Old 06-02-2013, 09:35 AM   #5
Rewards Points: 226
here it is. i'm not painting the asphalt siding. just the brown boards, cedar i think ?
Old 06-02-2013, 09:36 AM   #6
Rewards Points: 226
oh. i bought some zinzer 1-2-3. is that ok ?
Old 06-02-2013, 09:50 AM   #7
Rewards Points: 5,974
Since you already bought the 123 and it is a temp fix go ahead and use it.
Old 06-02-2013, 09:55 AM   #8
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Definitely prime then paint (exterior paint).
With the Zinnser 1-2-3 (latex), you might need to do two coats if the wood tannins bleed through on the first coat.
Sir MixAlot is offline   Reply With Quote
Old 06-02-2013, 10:04 AM   #9
Rewards Points: 226
i know it will need at least 2 coats. thanx
Old 06-02-2013, 09:26 PM   #10
Rewards Points: 226
got it primed. 2 coats, and still not 100% coverage. but its good enough.
this made a good difference on how my house looks. little things
Old 06-14-2013, 10:27 PM   #11
Painting Contractor CT
Rewards Points: 77
Post
prime or paint ?
Use oil based cover stain primer then paint with latex paint.
Good Luck!
KD PAINTING is offline   Reply With Quote
Old 06-15-2013, 09:30 AM   #12
Primer is not meant for 100% coverage paint is.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
Fix'n it (06-15-2013), Gymschu (06-15-2013)
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Satin paint and prime over semi-gloss DebMcniel Painting 5 01-28-2012 04:15 PM
is pressure washing enough then prime and paint? NWFixer Painting 1 06-09-2011 05:31 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
