Prime After Wallpaper Removal - Painting - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 10:11 AM   #1
Prime after wallpaper removal
Must you prime with one of the blocking primes,Gartz etc. after you remove wallpaper and then want to skim coat. Can you just skim coat without priming the wall
stevenson66 is offline   Reply With Quote
Old 11-08-2010, 10:49 AM   #2
Faron79's Avatar
Rewards Points: 260
YES...it's a MUST. PERIOD.
I'd never give clients THAT advice (skipping Gardz)!!!
Using Gardz sealer >>> after all glue is removed and rinsed well <<< guarantees no problems with drywall paper-edges lifting, etc. Any exposed gypsum is sealed-off too. Basically, Gardz "glues everything down".
The ONE/RIGHT way to do this:
* Scrape/rinse, rinse, rinse/let dry.
* Prime with Gardz.
* NOW you can safely do repairs/mudding, etc.
* When repairs are sanded and rinsed and wall is TOTALLY dust free...
* Apply a good/full coat of a top-notch primer like 123. PVA "wallboard" primers are OK, but 123-class primers are MUCH better.
* AT LAST ...you're ready for TWO good finish coats.
See?! Doing it RIGHT means you have to prime TWICE !!
Faron
Faron79 is offline   Reply With Quote
The Following User Says Thank You to Faron79 For This Useful Post:
spiceoflife (09-10-2011)
Old 11-08-2010, 12:45 PM   #3
40+yrs Paint Trades
I've never used Gardz. What's it about? My preference is Zinnzer 123 or Kilz plus for acrylic and Kilz regular for oil based.
hoz49 is offline   Reply With Quote
Old 11-08-2010, 05:05 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
http://www.zinsser.co.nz/wtb-GARDZ.asp?SID=11&WID=27
Old 11-08-2010, 05:16 PM   #5
40+yrs Paint Trades
Thx 4 the pic. I've seen it on the shelves. What is it like? thick, thin? Pigmented, clear? In other words, "what's it about?"
Old 11-09-2010, 12:57 PM   #6
chrisn's Avatar
Rewards Points: 236
Very thin and watery and clear, but it does the job of sealing residual wall paper paste.
Old 11-09-2010, 05:04 PM   #7
prime after wallpaper removal
After removing all the paper and getting as much glue off that i can i realize that i have some bad areas because of picture and shelve hanging and removal. Should i roll on Gardz first then do the repairs and skim. Or should i do the repairs then Gardz and skim
Old 11-09-2010, 06:11 PM   #8
chrisn's Avatar
Rewards Points: 236
Before AND after.
Old 11-11-2010, 09:50 AM   #9
I just used Gardz on my kitchen walls after wall paper removal, and I have to say it is a little tricky to do! It's pretty much like skim milk! I used a brush and roller, you have to get it on just thick enough to completely cover the wall, but not too much or it runs down like water. I just used my roller to go over the same spot until it was just right. It takes 30 min to dry, but when it does it looks pretty nice. I don't need to skim coat cuz my walls were in prettty good shape, just patched a few nail holes and small cracks in the corner! Good luck!
sychopants is offline   Reply With Quote
Old 11-11-2010, 05:57 PM   #10
chrisn's Avatar
Rewards Points: 236
You really need a micro fibre cover( such as this) for this product.
http://www.thepaintstore.com/ArroWor...ver_p/mfr2.htm
Wallpaper Removal Choices in Kitchen LeviDIY Painting 14 12-02-2011 04:30 AM
Wallpaper removal and lead paint risk? rhena Painting 12 06-07-2011 05:30 PM
prepping walls after wallpaper removal.... diy'er on LI Painting 10 11-09-2010 09:57 AM
Wallpaper Removal saggdevil Painting 1 06-01-2009 05:31 AM
Wallpaper removal diylady Painting 10 10-01-2008 08:23 PM
