I am painting a bar area, it is currently a 1960's orange. I am going to paint it BM Regal, Bayshore beige. Do you think I should give it a coat of BIN or would you just go ahead with the Regal?
Jamie
Though two coats Regal covers pretty well, I'm guessing the groovy color is a bit bold, and a bit old
It's never a bad idea to prime older paint as it's often very "thirsty", and can cause uneven application and sheen of the new
Even w/o seeing the color difference, I'd say a coat of primer would be a good idea
Though I would not recommend BIN by any means
BM's Fresh Start acrylic would be just great
Heads Up: It doesn't have to look like a new freshly painted white wall after priming, just one coat to seal it and tone down the orange
It's overkill for this project
It certainly is one of the best...arguably the best sealer out there
But it's also difficult to apply and quite the brain cell killer
Save it for sealing/priming the old dark brown (and maybe lacquered, shellacked or maybe poly'd who can tell) trim and doors, or the fire damage, furnace blow-back coated, or nicotine coated walls...or mouse/pet odor sealing
...or you may want it for that groovy '70s slick dark paneling in the other room
...unless, of course, you have the avocado appliances and the brown and orange giant-flower-patterned mega high pile super-shag carpet to go with the paneling and want to keep it
I agree, it is more difficult to apply than most other paints I have used. Kind of like spreading water. But I had a can of BIN and just wanted it done. It was one of those evil orange colors, (I wonder what people will say about that deep deep red we are all using now when they try to paint over it in 20 years) that BIN even had a really hard time covering in one coat. I am sure it will be fine with a top coat of regal. I am really glad I listened to you can put a coat of primar on it, or I would have ended up with 3 coats of regal or .... Thanks.
No retro appliances. I do have the wood paneling thing, however, I am fortunate that it is all oak, and still looks fairly classy, it doesn't look nearly as retro as most of the old paneling I have see out there.
Orange shag carpet was there,, but went 2 years ago. LOL!
Just FYI, the vast majority of primers have lousy "hide." Most primers exist as a surface and/or stain sealer and adhesion enhancer; for the most part they have very little pigment, even compared to cheap paint. Unless a primer is specifically designed for hide, (they do exist), you would not expect them to cover up a deep existing coat at all. That is paint's job, and that is what quality paint is made for.
What's the tint formula of the paint you plan to put over the old orange paint? If it's "Bayshore Beige", I'm guessing it'll have a lot of inorganic pigments in it, and be fairly light as well. So, you should get pretty good hide right from the Bayshore Beige.
If it were me, I'd just clean the old paint with a green 3M Scotchbrite pad allow time to dry, and apply a coat of Bayshore Beige to a small area about 6 inches by 6 inches a 1 inch foam brush. Allow to dry, and then paint half that area (3 inches by 6 inches) with a second coat of Bayshore Beige. Allow to dry and paint half THAT area (3 inches by 3 inches) with a third coat of Bayshore Beige.
If you can see a difference in colour density between two coats and three, then I'd be inclined to use a tinted high hiding primer as your first coat.
If you can't see any difference between two coats and three, I'd just clean the old orange paint with either TSP (if it's an oil based paint) or a green Scotchbrite pad (if it's latex paint) and just start painting (without using a primer first).
I ended up giving it a light cleaning and applying a coat of BIN. Bin had fairly good hide and the surface was very very easy to paint with the Regal.
1 coat of regal on top of the BIN and it is done. I don't think it could get any better with a second coat. I was truely amazed at home nice and easy the regal went on.
It's kind of funny, BIN works so well, but is is really fairly difficult to get on correctly (have to be careful not toget roller marks and drips, but I have used it a few times now and have it down pretty well.) The BIN kind of reminds me of cheap home depot behr paint, I did my whole living room witn deep garnet (red) from behr this summer. What a BEAR, it was a lot of work, but I learned how to roll properly, because if I didn't the bear looked like crap right away. My red wall looks perfect and professional, and I greatly improved my rolling skills on that project, if I had not done that red first and learned how to roll pretty well, I would have really had trouble with the bin.
Thanks guys for the help. Turned out to work out very well with just the 2 coats, which I am very happy about due to a fair amount of cut in work in this little job.
Jamie
I would think 2 coats will cover it. Primer can't hurt, but may just be adding a 3rd coat (one coat of primer and 2 coats of paint verses just 2 coats of paint)
Excellent. Ya the Regal is good stuff. Sherwin Williams has comperable stuff as well. The Behr paint? Before people ever say that Regal is over priced compared to Behr really needs to go get a can of that $10 - $12 Glidden stuff and see that is it right on par with the Behr and then see decide what is overpriced.
The "cheap" paint (behr, glidden,etc.) just are not worth the struggle. I learned you can make them work if you want to take the time, but it isn't worth it.
It doesn't hurt that I keep finding these gallons of regal as mised tints for $5. I find them in the same color in pairs. not sure how that happens, but I paid $4.99 a gallon for these 2 matching gallons of bayshore beige.
I don't always get that lucky, sometimes I have to pay full price, but have gotten really lucky several times watching the mised tints.
Jamie
Related Threads
DIY Home Improvement Forum
3.1M posts
320.1K members
Since 2003
