Prevent Bleeding Through Tape When Painting - Painting - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 05:21 PM   #1
nurse_medic's Avatar
Lightbulb
Prevent bleeding through tape when painting
hello, I have been trying to paint a red stripe on the (textured) bathroom wall. I used blue painters tape only to have the paint bleed through. I then placed green frog tape about 3/8 of an inch down to fix the bleed through lines with NO success. Same thing. I know that red is an unforgiving color and I didnt want my stripe to end up being 4 inches wide. I had a thought...try electrical tape. It worked awesome!! No bleed through, nice straight lines. I did remove the tape as soon as I finished painting to minimize potential damage to the other paint on the wall.
just thought I would share this--hope it helps.
nurse_medic is offline   Reply With Quote
Old 11-17-2010, 08:33 PM   #2
Paint Store
did you moisten the frog tape?
DCCenter is offline   Reply With Quote
Old 11-17-2010, 10:15 PM   #3
Faron79's Avatar
Rewards Points: 260
Frogtape always does it for our customers.
If it didn't for you, the texture may be too rough for it to prevent all capillary bleeding.
* What ALWAYS helps is using just a TRACE of painter's-caulk wiped lightly at the tape-edge.
* Wipe visible amounts off with a clean/dry cloth. You'll be leaving just a teeny bit of caulk...if you can't see it...IT'S ENOUGH!
* Now your lines will be perfect.
A similiar technique is to use just the paint itself.
* Brush just a light haze of paint at the tape edges.
* There won't be enough paint to bleed...it'll dry too fast.
* This works 97% of the time.
The caulking-version is TOTALLY foolproof however, especailly if texture is a little heavier.
Also: Don't bring a load of paint onto a taped edge. Unload most of the paint AWAY from the edge, bringing only the brushed-out film to this edge.
When you have a bunch of paint at the tape, the capillary-pull is much stronger.
Faron
Faron79 is offline   Reply With Quote
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 09:36 AM
Need to Patch Holes on Newly Skimcoated Wall: Use Tape? Lovegasoline Building & Construction 6 12-06-2009 04:31 AM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 07:56 PM
Drywall tape sticking out vancouver Drywall & Plaster 5 09-08-2009 11:04 PM
Settling House Painting Problems Gungadin Painting 6 11-09-2005 09:51 PM
