Pressure Washing Soap/detergent Questions - Painting - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 11:46 PM   #1
Rewards Points: 12
Pressure Washing soap/detergent questions
I'm getting ready to pressure wash my house in preparation for painting.
I have two questions: 1) What have you found works well as a cleaner in your pressure washers? I'm partial to making my own, but am not opposed to buying a concentrate. I really don't have mold, so I don't think I need to use bleach. Most home made formulas mention TSP, but I'd rather avoid using phosphate. I know there's a phosphate-free TSP, but I don't know if it's available in my area. Other formulas mention laundry detergent or dish detergent. Any suggestions re ingredients and proportions would be appreciated. 2) I have 1,500 s.f. of exterior wall to wash (T1-11 siding). How much soap/detergent will I need?
Many thanks in advance
psychopengy is offline   Reply With Quote
Old 07-15-2013, 07:31 AM   #2
Gymschu's Avatar
Rewards Points: 178
I've been in the painting business for well over 30 years and RARELY use any type of cleaner. For the most part the PW does the work and removes dirt and grime with the PSI alone. If I see stubborn mildew/dirt, I get out my garden pump sprayer, fill it with some KRUD KUTTER and water, spray it on the area in question, let it marinate for 10 minutes, and then scrub it with a scrub brush on a pole. Then I hit it with the PW.
KRUD KUTTER is good stuff, safe for the environment and very effective as a mildew killer. Buy a gallon of the concentrate and it will last for the entire summer.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
ltd (07-15-2013), ToolSeeker (07-15-2013)
Old 07-15-2013, 05:44 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
I'm with you
Old 07-15-2013, 08:03 PM   #4
Gymschu's Avatar
Rewards Points: 178
Originally Posted by chrisn View Post
I'm with you
Chris, I'm finally making my way up the "ChrisN A List?"
Old 07-15-2013, 08:15 PM   #5
Rewards Points: 6,652
Best kind of cleaning detergent out there is Tide.
Old 07-15-2013, 09:09 PM   #6
member
When you talk of using Krud Kutter which one are you using, I looked up Krud Kutter and
they must have 5 or 6 Krud Kutters for exterior washing?
mcrannell is offline   Reply With Quote
Old 07-16-2013, 03:56 AM   #7
chrisn's Avatar
Rewards Points: 120
Well, we both live in the "mountains", so that helps
Old 07-16-2013, 07:32 AM   #8
Gymschu's Avatar
Rewards Points: 178
<img src="http://images.lowes.com/product/converted/618818/618818811208lg.jpg" alt="Krud Kutter 1-1/4-Gallon Concentrated House and Siding Cleaner"/>
Oops, didn't copy and paste so well........but I get the 1 1/4 gallon green concentrated house and siding cleaner from Lowe's.......about $12.
The Following User Says Thank You to Gymschu For This Useful Post:
mcrannell (07-16-2013)
Old 07-18-2013, 01:52 PM   #9
Painting Contractor CT
Rewards Points: 77
Post
Use bleach, been using it for years and it works great.
KD PAINTING is offline   Reply With Quote
Old 07-20-2013, 10:56 PM   #10
Rewards Points: 4,780
I was starting to think I was the only one.
But the problem is 2 (or 3) story houses. Getting either a sprayer or the PW spray up high is the awkward part.
jeffnc is offline   Reply With Quote
Watts Pressure regulator does not hold water pressure goshenplumber Plumbing 4 05-05-2013 10:54 AM
Ultra high shower pressure carlk4574 Plumbing 1 03-14-2013 09:03 PM
replaced pressure tank still no water? Lynn and Bill Plumbing 9 05-07-2012 10:26 PM
pressure washing 7echo Painting 10 04-29-2012 03:43 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
