-   -   Pressure Washing - Reaching tall house? (http://www.diychatroom.com/f4/pressure-washing-reaching-tall-house-143332/)
HandyFrank 05-10-2012 11:13 AM
I'm about to buy a Ridgid 3000 PSI 2.6GPM pressure washer and was curious if these pressure washers can reach up to a 2nd and 3rd story of a house? I'm guessing it needs an extension wand but I'm not sure.
Anyone know if an extension wand will do it, or do I have to bite the bullet and still get up on the ladder?
gregzoll 05-10-2012 12:16 PM
You need to use a portable lift, not ladders. A whole lot safer.
ddawg16 05-10-2012 01:28 PM
What he said.....
Even with an extension....you mgiht be able to get the 2nd story done....but third story?
This is why you hire someone....chances are they will be as cheap as the lift rental....or at least close.....and safer....
dogris 05-10-2012 02:16 PM
For washing the dirt and mildew, look into downstreaming soap and bleach. Depending on your washer's output, using the proper nozzles you may be able reach 25-30 ft. high while standing on the ground.
HandyFrank 05-10-2012 02:30 PM
Thanks for the feedback guys. I wasn't looking forward to being on a ladder but I've seen people doing it that way. I poked around a bit more and on another forum someone suggested a telescoping extension. They have ones that go from 8'-18' for about $120.
I'm not a professional so a portable lift is out of the question. I bet that extension is going to do the job perfect.
kwikfishron 05-10-2012 04:34 PM
199 Attachment(s)
Even with the red tip if your not within about 10'- you're not cleaning anything, you're just getting it wet.
chrisBC 05-15-2012 02:30 AM
invest in a good solid extension ladder
CaptRandy 05-15-2012 08:31 AM
With the right equipment you can reach up to 40 ft high. It is called an x-jet and it is a specialized nozzle that is used to inject soap and then rinse. When you clean sidingalways start from bottom to top and rinse form top to bottom. I have been cleaning houses for 10+ years and never left the ground to do one.
