Pressure Washing Causes Splinter In Wood - Painting - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 06:09 PM   #1
pressure washing causes splinter in wood
So I pressured wash the exterior wall and it splinter the wood trim on the garage door and the roof trim. How do i remove all the splinter to prep the trim for painting?
bbcmp1979 is offline   Reply With Quote
Old 05-30-2012, 06:46 PM   #2
Rewards Points: 150
Sand paper with orbital sander. What nozzle did you use on PW, should never use red or yellow.
CaptRandy is offline   Reply With Quote
Old 05-30-2012, 06:53 PM   #3
Rewards Points: 14,306
Wrong nozzle, held it to close, or rotten wood.
Time for a random orbital sander.
Old 05-30-2012, 08:16 PM   #4
yest i did use the yellow 15deg, i'll probably be using 35deg next time... So i went and sand it down w/150grit on an orbital sander. It is much better now, I'm probably use some wood filler before priming them though. Unless you guys think i should just prime it.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
trex decking installed over pressure treated wood leeken54 Building & Construction 3 05-01-2010 05:11 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
Pressure Treated Wood Appearance... Melanie337 Painting 7 08-04-2008 09:51 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
