#1 |
pressure washing
I am going to wash the exterior--vinyl siding/soffits and windows, and brick walls.
What do you all like for a cleaner? I plan to use a brush to scrub all the vinyl. House is under a lot of trees so there is some mildew, but mostly dirt. Comments and suggestions are appreciated. |
#2 |
pressure washing
Are you using a pressure washer? If so mix 2 gal bleach, a shot of Dawn liquid dish detergent(make sure it does not have oxiclean in it) and top off a 5 gal buck with water. Spray it on using the black tip from the bottom to the top of the house. Let it sit and rinse off using a 20 degree tip from the top down. The brick walls do the same.
Do not let the mixture dry especially on the windows. |
#3 |
pressure washing
Safety glasses if spraying bleach. Don't want to damage a cornea!
#4 |
pressure washing
Definitely agree. I wear them all the time so I forget to tell it. Also a face mask, with a valve to breathe and not fog glasses.
#5 |
pressure washing
OK, I have those ingredients handy.
What about TSP? Is it not good for vinyl or brick? |
#6 |
pressure washing
I actually used to use Simple Green or Purple Power from the auto store although I am not sure you are supposed to run them through power washers. I was careful to rinse the system thoroughly.
You did mention you were going to do some brush work too! Powerwashers are great but nothing yet beats getting at siding with a brush and/or car wash sponge and a power wash (on low) rinse. And be careful not to saturate water up under the siding or problems you never dreamed of will happen. |
| The Following User Says Thank You to sdsester For This Useful Post: | Gymschu (04-28-2012) |
#7 |
pressure washing
In my neck of the woods (Ohio) we have a product called "the Boss" cleaner which is like sdsester's Simple Green or Purple Power. Depending on how much dirt is on the siding, I dilute the Boss cleaner accordingly.......usually 3 parts water to 1 part cleaner........I mix it up in a garden sprayer with hot/warm water. I pre-wet the siding with a garden hose. Then I apply the boss from the garden sprayer and allow it to marinate. Working in the shade allows for more open time to let the cleaner work. It's amazing how much grime can be loosened up by a good cleaning solution. After 5-10 minutes (longer if you are able) I scrub with a soft bristled brush and rinse with the PW set low or a garden hose works also. Like Sdsester stated, vinyl can be tricky to clean with a PW. The water tends to get into the seams and it pours out bringing ugly dirty plywood particles with it that stick to and stain the vinyl. You CAN use a pw, but be very, very careful.
#8 |
pressure washing
I clean about 100 houses a year and use 12% bleach on them, whatever you decide to use just go slow and keep aware of your surroundings like wires and other obstacles. Never use a straight stream from the power washer, if you have a red tip throw it away, in 20+ years I have never had a situation that needed it.
#9 | |
pressure washingQuote:
![]() His wife called and said I had to see it all. "He has done worse than Tim the Tool Man!" We flipped the deck boards over and all was well but I had to laugh. Sorry. Last edited by sdsester; 04-28-2012 at 01:52 PM. |
#10 |
pressure washing
After 20 some years and so many DIY Instant PW's I have become an old hand at flipping boards. Still charge for the work.
Have a deck to do that the client had her grass cutter do because she felt sorry for him. He cleaned with water not bothering to remove any old coating and then coated with Cabots Solid. Waited a day and recoated. Second coat is sticky and shiny. It never had a chance. Now it has to be stripped, neutralized and then sealed properly. She actually wanted me to hire him, without pay because he caused the problem in the first place, to help do the job. What is his incentive to do what I tell him? I am not paying him. Needless to say I am doing the job myself and charging for his mistake and getting it done properly. |
#11 |
pressure washing
Last year I cleaned my vinyl siding that is yellow, but was greenish/brown from tree algae and dirt buildup. I didnt want to use a PW as its too much effort plus, I didnt want to "test" the waterproofing skills of the siding installer 20 + years ago...
So I bought something my neighbor recommended. Just mixed it per instructions and sprayed it on the siding with a garden style pump sprayer, then rinsed it off with a garden hose. Siding looks like new. Lowes product - JoMAx. |
| The Following User Says Thank You to Jeeps For This Useful Post: | Gymschu (04-29-2012) |
| Display Modes | |
| Well pressure tank operation........need some opinions | JayBird | Plumbing | 5 | 12-27-2011 05:36 PM |
| well pressure going down/ help | bsa_bob | Plumbing | 5 | 12-26-2011 03:24 PM |
| Slantfin Galaxy Boiler Pressure Mystery | chiefswabjockey | HVAC | 18 | 11-15-2011 06:37 PM |
| Pressure washing a house | bigbavarian | Off Topic | 2 | 05-13-2010 06:20 PM |
| Pressure washing siding | bluefitness | Painting | 11 | 02-04-2009 06:33 PM |
