Old 12-16-2012, 04:16 PM   #1
pressure washer problem = Help?
Have a Honda PW, about 5 yrs old, and every 5 minutes the tip nozzle clogs with a tiny shard of metal about 1-2mm wide. Could this be the pump innards breaking up?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 12-16-2012, 05:03 PM   #2
It is possible, can't realy tell unless you tear it apart. The only moving parts that could get into the water stream would come from the pump itself. I have tore several different pumps apart to fix them over the years. Not too hard to do.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
noquacks (12-16-2012)
Old 12-16-2012, 06:53 PM   #3
OK, good to know. So, what exactly in the pump is made of steel/stainless steel? (unless another type metal......)
Old 12-16-2012, 06:54 PM   #4
I imagine there are pump parts that are made of other materials as well, right(nylon, teflon/etc etc??)
Old 12-16-2012, 09:22 PM   #5
All depends on which pump they used. There are only a handfull of units that all manufacturers use
Old 12-17-2012, 06:14 PM   #6
I am looking for a curved pressure washing attachment to clean gutters anyone know of any?
GreenBoyz is offline   Reply With Quote
Old 12-18-2012, 08:31 AM   #7
Matthewt1970's Avatar
n/m....
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 02-08-2013, 02:55 PM   #8
Grants Painting's Avatar
Metal chips. I could only think that they are making their way from the bottom end of the pump(behind the plungers). If that's the case you will need a new pump.
Does it leak horribly?
Grants Painting is offline   Reply With Quote
Old 02-09-2013, 04:27 PM   #9
Any kinks in the hose? inlet filter? Look for easy fixes first before you tear down a pump. What kind of pump will determine if worth a rebuild or trash.
BTW do not stand over the hose if it bursts.
CaptRandy is offline   Reply With Quote
Old 02-09-2013, 08:25 PM   #10
Gymschu's Avatar
I purchased one at Lowe's. It was part of a telescoping nozzle attachment I got for my Troy Built pressure washer. Gets you as high as most two story homes.
Honda pressure washer not making pressure brandon1023 Tools 1 07-23-2012 06:29 AM
Craftsman 7 HP pressure washer model 580.762601 Princessfreddy Tools 3 11-15-2011 02:16 AM
Campbell Hausfeld 2030 Pressure Washer Problem 68rs327 Tools 3 11-09-2011 11:04 AM
Hot water pressure problem (unusual situation) tanna Plumbing 2 09-03-2011 09:17 AM
Home water pressure problem ATLdrew Plumbing 13 04-24-2009 12:17 PM
