-   -   pressure washer problem = Help? (http://www.diychatroom.com/f4/pressure-washer-problem-help-166625/)
noquacks 12-16-2012 03:16 PM
Have a Honda PW, about 5 yrs old, and every 5 minutes the tip nozzle clogs with a tiny shard of metal about 1-2mm wide. Could this be the pump innards breaking up?
danpik 12-16-2012 04:03 PM
It is possible, can't realy tell unless you tear it apart. The only moving parts that could get into the water stream would come from the pump itself. I have tore several different pumps apart to fix them over the years. Not too hard to do.
noquacks 12-16-2012 05:53 PM
OK, good to know. So, what exactly in the pump is made of steel/stainless steel? (unless another type metal......)
noquacks 12-16-2012 05:54 PM
I imagine there are pump parts that are made of other materials as well, right(nylon, teflon/etc etc??)
danpik 12-16-2012 08:22 PM
All depends on which pump they used. There are only a handfull of units that all manufacturers use
GreenBoyz 12-17-2012 05:14 PM
Curved pressure wash head attachment
I am looking for a curved pressure washing attachment to clean gutters anyone know of any?:)
Matthewt1970 12-18-2012 07:31 AM
n/m....
Grants Painting 02-08-2013 01:55 PM
Metal chips. I could only think that they are making their way from the bottom end of the pump(behind the plungers). If that's the case you will need a new pump.
Does it leak horribly?
CaptRandy 02-09-2013 03:27 PM
Any kinks in the hose? inlet filter? Look for easy fixes first before you tear down a pump. What kind of pump will determine if worth a rebuild or trash.
BTW do not stand over the hose if it bursts.
Gymschu 02-09-2013 07:25 PM
I purchased one at Lowe's. It was part of a telescoping nozzle attachment I got for my Troy Built pressure washer. Gets you as high as most two story homes.
