Old 04-22-2012, 11:44 AM   #1
Pressure washer nozzle Q
I have a 4k 4gpm pump. I am wanting to reduce the pressure but not flow using the correct orifice # for a 40 degree tip. What would be a good orifice # for washing decking when stripping old stain? Thx!
Dick Handy is offline   Reply With Quote
Old 04-22-2012, 12:09 PM   #2
Please excuse my ignorance, but if it is a wood deck the wood will "hair up" from the PW blast before any stain can be removed. The only way I understand that stained wood can be returned to a natural state is by sanding it down to bare wood. Others in the know will be along shortly though. good luck
Jeeps is offline   Reply With Quote
Old 04-22-2012, 12:30 PM   #3
Jeeps right, unless it's a soild stain or paint that peeling off the deck a pressure washer is not going to take it off. Stain is just that, a stain deep in the grains of the wood.
Old 04-23-2012, 11:15 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Although you can strip-off paint, you cannot "strip-off" stain. It is proper procedure to pressure wash (clean) a deck, and allow it to dry, before re-staining.
Some information here, including recommended pressure:
http://www.restore-a-deck.com/pressurewash.html
http://www.power-pressure-washers.co...er-washing.htm
- Build Well -
Old 04-23-2012, 12:58 PM   #5
nozzles site fro ACR, but I think you are using way TOO much pressure for a deck. Dial back you unloader to 1200 psi
http://www.acrproductsinc.com/pressu...d=54&TreeId=17
CaptRandy is offline   Reply With Quote
Old 04-23-2012, 01:03 PM   #6
Painting Company, NY
housepaintingny's Avatar
Like Randy said, dial back the unloader or go with a tip some where's .072 orifice and that should lower you pressure to about 1000 psi. You will need a good deck stripper followed up with a neutralizer/brightener.
housepaintingny is offline   Reply With Quote
Pressure washer repair help jclemmojoe Tools 4 06-17-2011 08:47 AM
removing pressure washer spill valve goose00 Tools 8 04-20-2011 03:47 PM
Has anyone built a hot water pressure washer ? Sin-city-custom General Discussion 5 02-25-2011 06:32 AM
cleaning sewer lines with pressure washer ponch37300 Plumbing 3 07-06-2009 09:26 PM
What to look for in a Pressure Washer ? Scott_K Tools 5 07-03-2005 02:43 PM
