Pressure Wash Then Scrape, Or Vice Versa? - Painting - DIY Chatroom Home Improvement Forum
Old 07-09-2013, 08:22 PM   #1
Rewards Points: 12
Pressure wash then scrape, or vice versa?
Hi,
I'm new to the forum. Thanks to everyone who reads and responds to my posts.
I have a 918 sq. ft. house that I'm prepping for exterior painting. The siding is T1-11 (a type of plywood with vertical grooves). Much of the south facing wall and parts of other walls have flaking paint that I need to remove. It makes more sense to me to scrape the paint first, then pressure wash. If I pressure wash first, then I'll have to wash the walls again to remove the debris from the scraping. Or do people think that the pressure washing will remove all the loose paint? Maybe pressure wash in conjunction with a stiff broom or brush?
Also, I want to use some kind of soap/detergent/bleach mix. I was thinking phosphate-free TSP (it exists), but I'm open to other suggestions.
Thanks for your time.
psychopengy is offline   Reply With Quote
Old 07-12-2013, 09:46 AM   #2
Rewards Points: 394
You are correct.
Will22 is offline   Reply With Quote
Watts Pressure regulator does not hold water pressure goshenplumber Plumbing 4 05-05-2013 10:54 AM
replaced pressure tank still no water? Lynn and Bill Plumbing 9 05-07-2012 10:26 PM
Part2-Rumbling pipes and leaking pressure relief valve Homerepairguy Plumbing 9 04-24-2012 04:49 AM
Boiler pressure troubles jduffett HVAC 2 12-12-2010 08:15 AM
fittings and pipes sizes.. effect on pressure? cgerikh Plumbing 3 05-19-2008 11:37 AM
