Old 07-11-2009, 10:54 AM   #1
To pressure wash or not to pressure wash a previously stained cedar fence?
My fence is in not bad condition meaning few grey area except where the sprinklers hit the fence, and I have heard and read that the type of pressure washer that you rent have too much PSI and can actually damage the fence? If this is the case is their a fence cleaner that some of you have used and could recommend? Also here in Texas like much of the south our temperatures are in the 90's so am wondering if I should wait until cooler weather to clean and stain the fence? I have decided to use the Armstrong-Clark stain brand. If this question has been answered somewhere else just let me know. Any help would be appreciated.
rommel is offline   Reply With Quote
Old 07-13-2009, 08:23 AM   #2
NAV
there are many different PSI washers available and there are different tips you can use. just dont use a 0 tip and dont get too close to the fence with the wand.
the hotter is is the faster you have to work. try to work in the shade when staining and keep a wet edge. if the material dries and you overlap you will get what we call a "flash mark" - meaning that the material will be shiny in the overlapped area. when you can see Flashing in exterior stain you know that someone that doesn't know how to paint did that job.
NAV is offline   Reply With Quote
Cedar Wood Fence - Staining again ddave23 Painting 13 03-22-2012 06:43 AM
Pressure Treated vs. Cedar Posts for Porch missyz17 Building & Construction 15 08-22-2011 02:34 PM
Repaint cedar fence dderosier Painting 1 04-21-2009 11:45 PM
Cedar or PT Fence Posts??? C&D Landscaping & Lawn Care 15 04-08-2008 11:27 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
