Pressure Treated Wood Appearance... - Painting - DIY Chatroom Home Improvement Forum
Old 07-25-2008, 10:59 AM   #1
I have a new deck and wish I could keep the PT wood looking like new. I see there are a lot of water seal type products and bleach cleaners, but is there anything that will keep PT wood from turning gray...like having the wood wear sunscreen, perhaps? Thanks!
Melanie337 is offline   Reply With Quote
Old 07-25-2008, 11:12 AM   #2
Rewards Points: 2,906
I'll let the people more experienced with decks advise you on that...
...but, even if your wood does turn grey, you can remove that with a product called "wood bleach", also known as oxalic acid.
Nestor_Kelebay is offline   Reply With Quote
Old 07-25-2008, 11:50 AM   #3
747
registered
747's Avatar
Rewards Points: 534
It my understanding you have to wait on a pt wood deck for a little while before you do anything. And yes you can do something but i forget what its called. Meaning the guys on the other forum have something they like to go with.
Now that i think about it i haven't seen the one guy from colorado who builds awesome decks post in a while over there.
747 is offline   Reply With Quote
Old 07-25-2008, 03:39 PM   #4
Guest
Guest
Posts: n/a
Sikkens recommends at least 6 weeks for a PT deck to weather. I'd recommend longer than that. Even at 6 months I've seen chemical coming out of a deck. You can wash it down with a good Sodium Percarbonite based cleaner like Restore-a-deck, or Wolman DeckBrite. Wood bleach should only be needed if you have excessive staining.
As for a clear finish with UV protection, they are few in number and don't do the job all that well. The most widely known is probably Flood CWF-UV. I'd personally recommend a good pigmented semi-transparent stain like Sikkens SRD.
Old 07-25-2008, 11:37 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
A little pigment is needed for that UV protection
I'd also recommend a stain like Sikkens SRD or Cabot's Clear Solutions
Neither is a true clear, but both have a little tint to them
If you want a true clear, then go with Wolman's RainCoat
It comes it oil or water-based
slickshift is offline   Reply With Quote
Old 07-26-2008, 10:31 AM   #6
747
registered
747's Avatar
Rewards Points: 534
Thats it Cabot's. Guys on the other forum love that stuff.
Old 07-26-2008, 01:30 PM   #7
ccarlisle's Avatar
You know, that grey layer is actually quite thin and can be pressure-washed off. Then, as Nestor said, oxalic acid-based cleaners are the next in line for more severely greyed wood, then oxygen-based bleaches like Oxiclean (the trade name for sodium percarbonate),then something really strong like sodium hydroxide followed by an acidic neutralising rinse is the 'nothing left to loose' solution just before replacement.
Pressure-washing carefully is what I do every year or so...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 08-04-2008, 10:51 AM   #8
Thanks everyone...i think the light stain idea is best for me
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
how long to let pressure treated wood dry before painting? vendejp Painting 18 08-08-2012 09:53 PM
Pressure treated wood - attracts bees? mcvane Carpentry 4 08-31-2007 09:43 AM
Painting pressure treated wood Crackers Building & Construction 1 08-27-2007 11:51 AM
use of pressure treated wood in the garden bscout Landscaping & Lawn Care 7 06-07-2007 12:23 AM
