Pressure Treated Wood - Painting - DIY Chatroom Home Improvement Forum
Old 07-19-2013, 07:06 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Pressure treated wood
Can I paint pressure treated decking, ...(white)??
Barry
Barry J is offline   Reply With Quote
Old 07-19-2013, 07:09 PM   #2
Rewards Points: 13,950
If you do not mind having to sand and repaint it every few months.
Wooden deck boards need to be stained not painted.
Old 07-19-2013, 07:23 PM   #3
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Can we stain it with "white stain", I think Benjamin Moore has a white stain
Old 07-19-2013, 07:32 PM   #4
A white deck would show stains every time someone so much as walked on it.
Old 07-19-2013, 07:54 PM   #5
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Actually it is not for a deck, I am making a mounted board for hot tub **** off switch, outdoor outlets and a shelf for a TV, I've got two PT 2x4s cemented into the ground 2 feet apart. Then I was going to mount PT decking going across attaching the teo upright 2x4s.
I was going to mount all the stuff onto the 2x4s.
My wife wants it to be white.
Any suggestions??
Barry
Old 07-19-2013, 08:00 PM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,276
Actually, every manufacturer has a white stain (Opaque or solid color).
On the good side, it will breath better (but you'd better still give your PT several minths to dry out)
On a decking horizontal surface, in my opinion it is going to look terrible.... if you were just staining the substructure for appearance from underneath (windows underneath decking), it will probably make it look a little better.
Just an opinion
MTN REMODEL LLC is online now   Reply With Quote
Old 07-19-2013, 08:02 PM   #7
Any suggestions??
Barry
Get a new wife
Old 07-20-2013, 09:30 AM   #8
Davejss's Avatar
Rewards Points: 772
Get some pvc boards, Like Azek for instance. They are already white. No paint or stain required.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
Gymschu (07-20-2013)
Old 07-20-2013, 09:46 PM   #9
Rewards Points: 4,796
Wood can of course be painted, but new pressure treated wood is not a good candidate because the wood is so "wet" with the treating chemicals. You run a high risk of the paint failing. You can either use non-pressure treated, or put up the pressure treated and let it weather for 6 months before painting.
jeffnc is offline   Reply With Quote
Old 07-21-2013, 05:52 AM   #10
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Can Azek boards be sanded?
How important is pressure treated wood? lae26 Building & Construction 22 03-16-2013 12:25 AM
pressure treated wood project -- acceptable quality? bunchofquestion Building & Construction 6 11-09-2011 09:17 PM
Pressure treated wood? sharp Building & Construction 5 04-13-2010 07:50 AM
Best way to attach pressure treated wood to painted siding ? 1freebird Building & Construction 1 09-30-2009 10:02 PM
galvanized bolts for pressure treated wood? Jeremy Hillary Boob, PhD Building & Construction 11 07-10-2009 09:53 AM
