Pressure Treated Decking - Painting - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 05:15 PM   #1
pressure treated decking
if my decking has already turned gray , is it really necessary to use deck cleaner or can i paint right overit
tarisbulba is offline   Reply With Quote
Old 04-05-2011, 06:00 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
The gray is dead wood fibers. If you apply stain to that it will fail within a few months. You need to clean the deck with a quality deck cleaner and follow it up with a brightner. Wolman Deck Brite works well. It will remove the gray, remove dead fibers, mill glazing, dirt, mold and mildew. It will also open up the pours to accept stain. If you use quality products and low pressure from a pressure washer you can remove all of the gray and your deck will look new again before staining
housepaintingny is offline   Reply With Quote
Old 04-05-2011, 07:02 PM   #3
What are you planning to "paint" your deck with?
Pressure treated decking ChrisSask Building & Construction 1 03-14-2011 12:37 PM
Suggested Subflooring over pressure treated decking 112690 Building & Construction 2 10-19-2010 07:54 PM
Suggested Subflooring over pressure treated decking 112690 Building & Construction 3 10-19-2010 06:47 AM
trex decking installed over pressure treated wood leeken54 Building & Construction 3 05-01-2010 05:11 PM
Pressure Treated Decking Broncosfan1983 General DIY Discussions 2 09-13-2007 07:12 PM
