#1 |
prepping for painting on NC home
Hi all,
I am building a new home and the drywall guys just finished sanding. My wife had a conversation with the drywall guy who told her NOT to clean up all the dust and just paint away. They will wipe down the walls and we should be good to go. I about fell out of my chair!!! I have remodeled 2 homes and am no stranger to painting, but I have ALWAYS been meticulous about cleaning and prepping before laying down anything on a wall or ceiling. This not cleaning adice is nuts right? Another guy actually told me the dust helps the primer adhere to the walls and ceilings. Let me know your thoughts. |
#2 |
Retired
Dumb comment from someone that doesn't paint for a living!
Mike
THE ONLY THING THAT'S CONSTANT IS CHANGE |
#3 |
That is exactly what I thought. Along that same line, I've heard people here in So Tennessee complain that because of the humidity, (which actually isn't bad) they can rub the paint of the walls when they clean them.
I told them that's baloney, it's more likey a bad painting job. Thanks for the feedback. |
#4 |
Besides wiping the walls down, how do you intend to clean them?
#5 |
Any paint short of an industrial coating will come off if you use a harsh enough chemical in addition to some elbow grease. The lower the sheen the easier it is to damage. I don't believe the humidity is a huge factor. It gets pretty humid in VT and I don't recall ever hearing of such a thing. As for dust not needing to be cleaned up or dust making the paint bond better, it sounds like you already know the deal there. Hopefully he knows more about drywall than painting.
#6 |
as far as cleaning goes, once the DW guys finish their cleanup (scraping floors, brushing down walls etc.) I am going to vacuum all floors and window sills, then wipe everything down again, then start spraying.
#7 |
This is all new drywall, brand new home. Am I missing a step in cleaning?
#8 |
For me, I brush down the walls with a broom and vacuum up the dust. Primer is applied and allowed a day to dry. Then the wall is sanded and mopped off. Finish coats are applied with sanding and mopping in between coats. Finish comes out smoother than a baby's behind.
#9 |
There is no way that leaving dust on the wall can make paint stick better.
#10 |
I like to take a damp rag and wipe the walls down to remove as much dust as possible. No experience in spraying in a home, but I assume an even deeper cleaning would be in order.
#11 |
Hey everyone,
Priming is done. 5800 Sq ft of floorplan, used a graco x5 sprayer, 515 tip, set at about 60% max pressure. Looks great. Thanks to to folks who recommended back rolling. Made all the difference. Tray ceiling in the living room is 11 ft., even with the extension pole, had my arms at full height. can you say pain?? Have a friend helping who is a back rolling machine. Covered more than 5500 sq ft in 5 hours. painting ceilings tomorrow with ceiling paint. Thanks to all. will post pics soon. |
#12 | |
paper hanger and painter
prepping for painting on NC homeQuote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#13 |
Ran into a problem...
painting dining room with a fairly dark shade of red paint, over UNTINTED primer. I think I'm looking at 3 coats. Does that sound about right?Stupid me, should have thought about this ![]() Thanks |
#14 | |
Learning by Doing
Funny part was - it was a rental. We expected to loose our security deposit over the red walls. Guess the LL liked it, cause we got every dime back just about covered the cost of the extra paint
If I could only remember to THINK about what I was doing before I did it. |
| Display Modes | |
| Need advice on remodeling/renovating a prefab (mobile) home | countrylifemom | Remodeling | 47 | 03-20-2013 10:48 AM |
| mobile home service to bond or not to bond | rikmac | Electrical | 35 | 03-17-2010 04:47 PM |
| Owning a home (not a mobile home) on leased land? | Badfish740 | Off Topic | 11 | 03-30-2008 10:34 AM |
| Home Addition | destepan | Building & Construction | 6 | 12-05-2007 01:28 PM |
| A facelift for your home | Grumpy | Remodeling | 0 | 07-07-2004 08:43 PM |
