Prepping/Painting Fiberglass Entry Doors - Painting - DIY Chatroom Home Improvement Forum
Old 06-17-2013, 05:35 PM   #1
Rewards Points: 150
I realize there is a thread on painting fiberglass doors already, but I don't want to paint mine with oil-based rustoleum so I decided to start a new one.
Here's my scenario:
Two brand new Brosco fiberglass entry doors were installed last year, never been painted. One faces west and is always in the shade for the most part under an overhang and the other face east towards the ocean and is under an overhang. The east facing one see's a sea breeze all day, all night. Lots of salt air since we're only 6 houses from the ocean.
That being said, I want to do it right the first time as I don't want to keep stripping and painting it. How should I prep the door? What should I prime the door with? What finish paint should I use?
I'm leaning towards acrylic, but not really sure. If acrylic is the way to go, any favorite acrylic based primers and paints?
Squished is offline   Reply With Quote
Old 06-18-2013, 02:30 AM   #2
Too Short? Cut it Again!
In addition to the thread running just a few from yours, this comes up often so I would encourage you to use the search function search for the topic.
What does the manufacturer recommend for finishing the doors? Do they have any sort of primer on them now.
Since you have the salt laden moisture to factor in, you might want to see what marine products might be adaptable to your situation.
Old 06-18-2013, 09:16 AM   #3
Rewards Points: 13,256
The Brosco web site was of little help.
#1 It clearly states to paint as soon as it's hung.
All they suggest is use a quality primer and paint. No mention if it should be oil or latex.
I've used this before for doors and fiberglass columns and it came out smooth as a sprayed finish with just a foam roller and 2-1/2" sash brush.
http://pettitpaint.com/product.asp?id=45
Old 06-18-2013, 09:19 AM   #4
Rewards Points: 150
Yea, that's one of our problems is they weren't painted right away. So i need to prep/clean them first. I've been reading alot about marine paints, seems like a pretty good option only problem is the color choice and whether it will fit into the wife's plan.
exterior entry doors sheryl03818 Remodeling 3 01-11-2011 12:24 PM
vinyl shutters and fiberglass grain doors 4252 Painting 0 07-15-2010 12:38 PM
Reversing a fiberglass door? JonL General DIY Discussions 3 11-18-2009 07:32 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
fiberglass entry door adog Building & Construction 5 11-30-2006 11:11 AM
