-   -   Prepping for Paint (http://www.diychatroom.com/f4/prepping-paint-173168/)
LarryM 02-27-2013 09:09 PM
Prepping for Paint
So the finish guys I hired claimed they are done with my basement. I hung the drywall and they did all the corner beads, taping, and mudding. It looks like they did a great job outside of a few touch up areas. They did 2 coats of mud and sanded today at which point they collected their money and left. They said I am ready for paint.
However I don't think I am. I looked over the work and there is dust everywhere. I took my compressor and blew all the dust off the walls. I think I got most off and plan to blow it one more time.
So my question is if this is enough? Do I need to do anything else before I paint?
The plan is 1 coat of Ben Moore Fresh Start primer N023 and N024 for the room with MDF columns. Followed by 2 coats of Ben Moore Aura matte 0522. The ceiling will be Ben Moore Waterborne Ceiling Paint 0508
Gymschu 02-28-2013 09:20 AM
Sounds like you're good to go. I usually wipe down the walls with a soft-bristled hand broom to get the dust to the floor. Some painters go as far as VACUUMING the walls down to remove all dust but I find that takes lots of time and I always sand after the primer coat dries for 24 hours. After this sanding I use a damp sponge mop to remove any dust and then the walls are ready for paint.
joecaption 02-28-2013 09:29 AM
They must be some special finishers if there good enough to get it paint ready in just two coats, possible but not likly.
Might want to hold a stong light at an angle and recheck those seams.
It's normal to find a few flaws once the primer goes on so let it dry and recheck and repair the flaws, and reprime before painting.
I never would have used MDF in a basement.
ToolSeeker 02-28-2013 08:36 PM
Since these were finish guys and if they used bazookas, mud boxes, nail spotters compound tubes, corner rollers. You know real drywall tools, not what we use 2 coats is the industry norm.
747 02-28-2013 09:53 PM
I would prime the walls. Then just lightly sweep with a drywall screen. Now paint. Sometimes after priming you can get little needle pimples if you will. A light sweep with a drywall screen will make them disappear. I would have went with bulleye 123 then BM paint. Good luck.
http://www.homedepot.com/Building-Ma...1#.UTAYw1eRcfE
put a fine sanding screen on it. Just zip zap the walls after priming.
LarryM 03-03-2013 08:24 PM
Thanks 747, can you give me a link to a drywall screen?
I finished priming the theater with a 4base and it came out great. There are certainly a few spots I need to apply more spackle and sand smooth. What type of spackle should I use? Just some small holes the size of a pen tip. Is the green bucket too much?
The rest of the basement I did in white primer and it looks good except I need to do a 2nd coat
joecaption 03-03-2013 08:34 PM
Any box store will have sanding screen in fine medum and corse grit.
All your going to need is fine and a sanding pad.
Cheaper to just use a sanding sponge,
All are sold in the drywall area at any box store.
Only thing spackle is used for is tiny nail holes.
Use some thined green top and a wide knife,
LarryM 03-03-2013 08:46 PM
Ok great, I've been using green and a wide knife for the touch ups so ill continue that.
