Prepping Cut Wood For Finishing - Painting - DIY Chatroom Home Improvement Forum
Old 11-27-2013, 09:20 PM   #1
Unhappy
Prepping cut wood for finishing
I am making a pool cue rack and am trying to figure out how to prepare the cut ends, drilled holes and router surfaces for finishing without them getting darker than the rest of the rack. I have tried sanding with extra fine sandpaper with no success. Any suggestions would be greatly appreciated.
preil58 is offline   Reply With Quote
Old 11-27-2013, 09:49 PM   #2
DIY staff
Rewards Points: 7,174
End grain will get darker than the straight grained sections---
I soak the end grain with mineral spirits before I stain---this blocks absorption so the end grain is lighter---some folks use a 'stain conditioner' that product will block up the pores ,unfortunately,I have had problems with the conditioner blocking the stain to well.
I apply stain with a rag--wait one minute or so and then wipe off all that is not absorbed into the wood.--Mike----
Old 11-27-2013, 09:51 PM   #3
DIY staff
I moved this thread to 'painting'---you should get good advice here---Moderator--
Old 11-28-2013, 06:19 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Don't know if you will get any better advise
Old 11-28-2013, 06:45 AM   #5
DIY staff
Happy Thanksgiving Chrisn!
Some painters are staining wizards----
Old 11-28-2013, 07:52 AM   #6
Rewards Points: 5,974
You said you used extra fine sandpaper. Try using regular sandpaper on everything but the end grain then sanding the end grain a couple of grits finer.
Have never used it but have read about mixing your glue with water, like a sizing, let this soak in the end and seal it then sand lightly and stain. Try these on some scrap and let us know.
Old 11-28-2013, 10:55 AM   #7
Jmayspaint's Avatar
Rewards Points: 534
You could seal the end grain with a wash coat of shellac. Clear shellac thinned with alcohol about 50%. Apply to the end grains only, sand any excess off the sides. Same concept as using mineral spirits, or conditioner, but more effective at limiting stain absorption.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
ToolSeeker (11-28-2013)
Old 11-28-2013, 11:26 AM   #8
Davejss's Avatar
Rewards Points: 740
Just miter the ends and glue return pieces on the ends. No end grain and a nice finished look.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
Gymschu (11-28-2013)
Old 11-28-2013, 02:46 PM   #9
chrisn's Avatar
Rewards Points: 228
I'm NOT one of them, for sure
Old 11-28-2013, 06:03 PM   #10
DIY staff
That's okay---I can't hang wall paper to save my soul---
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
