As all you need is a slight, light, scuff sanding to dull the gloss a bit and give the next coat some "tooth", using a liquid de-glosser won't save any time
(scuff sanding should only take a few minutes per trim piece per wall)
However, if it needs cleaning anyway, using a Mr. Clean Magic Eraser, or a TSP product like Spic And Span, can also dull a high gloss enough to aid in adhesion...sometimes enough that no further sanding is needed
Honestly, I've never heard of vinegar for such a purpose
You'd certainly have to make sure it's fully rinsed off
It is by no means a "liquid sander" or "etching agent"
Not that someone couldn't have it work, but as mentioned above, another latex coat should stick anyway
The scuff sanding is "stacking the deck" in your favor, and well worth the effort to ensure proper adhesion...during application and years later
Liquid de-glosser are helpful if the piece is very ornate, and scuff sanding would only hit a few high spots on the piece
