Old 02-17-2013, 04:56 PM   #1
Preping walls for paininting!
I have just bought house 60-70 years old, we have stripped the walls of vinyl wallpaper that was very toughing to get off but now are now left with rough walls. What is the best way to smooth the walls?
priory is offline   Reply With Quote
Old 02-17-2013, 05:03 PM   #2
Post a picture.
#1 All the old glue have to go first, left one the paint does not have a chance.
The walls just may need a sanding cleaning and a skim coat of drywall mud to get them smooth again.
But without a picture no one knows just how bad there are.
Old 02-17-2013, 05:30 PM   #3
The walls are just mainly covered in glue left over from the wallpaper. We were told we needed an orbital sandier to make it smooth again but they are costly to buy. we have a hand sandier we used for the floors can we use this? Sorry if my questions are really silly... I have pictures but not of the full walls il get some to put up
Old 02-17-2013, 05:47 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
You can get the paste wet ( use a sponge or even a garden bug sprayer-) let it soak in and soften the paste- scrape the paste off with a 6" mud blade ( and a 4 to clean that off the 6) - then sponge any residue left.
Lightly sand to get any bits off- and then prime with a clear primer called Gardz.
then do any repair needed- prime repair and paint.
It's just that easy!! lol
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-17-2013, 05:49 PM   #5
A sander would just grind the glue into the wall.
The glue needs to be stripped.
http://removewallpaperpaste.com/
You think this is expencive?
http://www.cpoworkshop.com/factory-r...rbit%20sanders
Old 02-17-2013, 09:52 PM   #6
When the paste is that thick it needs to be bladed off, I use my mud pan and do some "reverse spackling".
jsheridan is online now   Reply With Quote
Old 02-18-2013, 04:43 AM   #7
paper hanger and painter
chrisn's Avatar
not even ONCE did the article you included use the improper term glue, did you read it?
Old 02-18-2013, 05:34 AM   #8
Not so, you read as fast as you write
Old 02-18-2013, 02:57 PM   #9
Great Thanks for the advice
Old 02-18-2013, 06:03 PM   #10
chrisn's Avatar
I stand corrected,but, he did say paste 42 times, adhesive once and the dreaded glue only twice
The Following User Says Thank You to chrisn For This Useful Post:
jsheridan (02-18-2013)
Old 02-18-2013, 06:05 PM   #11
Ya, but who's counting. Oh...
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
No Floating walls where there should be! DIY Master Building & Construction 1 02-23-2011 06:06 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
