Prepare And Paint A Water Stained Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 01-19-2010, 09:28 PM   #1
prepare and paint a water stained ceiling
What's the best way to prepare and paint over a ceiling water stain on a knock down drywall surface?
c44u2nv is offline   Reply With Quote
Old 01-20-2010, 05:32 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
Oil based stain blocking primer, paint
Old 01-20-2010, 07:11 AM   #3
Thanks for your reply, but should I attempt to lighten the stain and clean the are first with a watered/bleach solution or other cleaning agent?
Old 01-20-2010, 12:13 PM   #4
Too Short? Cut it Again!
Have you resolved whatever caused the stain? I don't think bleaching it is going to accomplish much. Just use the stain blocking primer as suggested, two coats if you want. If the drywall was compromised in this you should probably cut out the damaged sections and replace.
Old 01-20-2010, 01:53 PM   #5
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
I'm going to get reprimanded for this, but, I must do what I must do.
Easy to use for small spots. No need to clean out a brush or roller. available at your favorite big box store.
Kevin
Kevin M. is offline   Reply With Quote
Old 01-20-2010, 06:18 PM   #6
chrisn's Avatar
Rewards Points: 236
Hey, that works just fine for a small area,I use it all the time, smells bad but works.
Old 01-20-2010, 07:00 PM   #7
Kevin M.'s Avatar
Rewards Points: 150
That was close one. I know you Paint talk.com guy's are lurking around looking for a noob to tweak. makes me a bit nervous
Kevin
Old 01-21-2010, 04:41 AM   #8
chrisn's Avatar
Rewards Points: 236
Kevin
Someone is always watching, be careful
Old 01-24-2010, 08:42 PM   #9
Rewards Points: 252
ChrisN - have you tried SMart Prime from zinsser yet?? It claims it is the best of both worlds, property of water but seals like a solvent based - specifically says good for water stains. Haven't tried it yet but tempted
mazzonetv is offline   Reply With Quote
Old 01-25-2010, 05:10 AM   #10
chrisn's Avatar
Rewards Points: 236
If I could get it I would, but it is not around my thriving metropolis as of yet.
Bubbling Paint - Re-do Roddy Piper Painting 6 08-26-2007 02:26 PM
how to remove peeling semi-gloss paint amydiy Painting 5 04-09-2007 10:06 PM
