-   -   prepare and paint a water stained ceiling (http://www.diychatroom.com/f4/prepare-paint-water-stained-ceiling-62321/)
c44u2nv 01-19-2010 08:28 PM
What's the best way to prepare and paint over a ceiling water stain on a knock down drywall surface?
chrisn 01-20-2010 04:32 AM
2 Attachment(s)
Oil based stain blocking primer, paint
c44u2nv 01-20-2010 06:11 AM
Thanks for your reply, but should I attempt to lighten the stain and clean the are first with a watered/bleach solution or other cleaning agent?
user1007 01-20-2010 11:13 AM
Have you resolved whatever caused the stain? I don't think bleaching it is going to accomplish much. Just use the stain blocking primer as suggested, two coats if you want. If the drywall was compromised in this you should probably cut out the damaged sections and replace.
Kevin M. 01-20-2010 12:53 PM
I'm going to get reprimanded for this, but, I must do what I must do. :thumbup:
http://www.azpartsmaster.com/images/...op/KILZ-UP.jpg
Easy to use for small spots. No need to clean out a brush or roller. available at your favorite big box store. :yes:
Kevin
chrisn 01-20-2010 05:18 PM
Hey, that works just fine for a small area,I use it all the time, smells bad but works.
Kevin M. 01-20-2010 06:00 PM
That was close one. I know you Paint talk.com guy's are lurking around looking for a noob to tweak. makes me a bit nervous :eek::laughing:
Kevin
chrisn 01-21-2010 03:41 AM
Kevin
Someone is always watching, be careful:jester:
mazzonetv 01-24-2010 07:42 PM
ChrisN - have you tried SMart Prime from zinsser yet?? It claims it is the best of both worlds, property of water but seals like a solvent based - specifically says good for water stains. Haven't tried it yet but tempted
chrisn 01-25-2010 04:10 AM
If I could get it I would, but it is not around my thriving metropolis as of yet.:wink:
