Prep For Repainting A Wood Porch - Painting - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 02:43 PM   #1
prep for repainting a wood porch
hi there,
I'd like to repaint the deck of my wood porch. the old paint job is dry, peeling, dirty, etc. the porch is made from tongue-and-groove planks.
what is an acceptable way to prepare the porch for new paint? can I get away with just using a belt sander then scrubbing it clean?
also, if anyone has any recommendations for a good porch primer/paint combo, I'd appreciate it.
thank you!
nelsonC is offline   Reply With Quote
Old 01-27-2009, 05:44 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Scrape and sand
I would recommend a solid stain rather than a paint
Sikkens, Cabot, Benjamin Moore, and Sherwin Williams all have good ones recommended for decks
slickshift is offline   Reply With Quote
Old 01-28-2009, 12:05 PM   #3
cool, scrape and sand is what I had in mind!
the wood isn't that beautiful for staining, and I like the lower-maintenance aspects of a good primer/paint combo. plus, having the added color will look nice with the overall design of the exterior.
so - any good primer/paint combos, brands, types?
thanks again.
Old 01-28-2009, 12:54 PM   #4
I assume he is referring to the newer 'opaque' deck stains which look pretty much like paint, but will wear much better - It's not like you'll see the grain with them.
Cabot opaque deck stain got good marks from Consumer Reports for durability, so I used that. It hasn't been long enough to know about longevity yet, but it went on smooth and easy and the color (sorta dove grey) looks great. I don't remember whether I washed the raw wood down with Tri first or not - Probably not.
miami is offline   Reply With Quote
Old 01-28-2009, 01:37 PM   #5
excellent. thanks for the clarification! just wanted to get a bit of info before heading to the paint shop.
Old 02-01-2009, 11:46 AM   #6
Git er dun
tongue and groove............ i suggest you have a steel brush on hand to "scrape/brush" and worthy primer before painting.
todolist is offline   Reply With Quote
Old 02-02-2009, 08:13 AM   #7
Tom Struble's Avatar
Rewards Points: 2,002
the deck strippers on the market do a pretty good job also make sure to follow the directions and use a neutralizer after.Sand areas that need it and let dry thoroughly.Make sure you use a paint or stain specifically made for decks. good luck
Tom Struble is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Replacing Porch Column base, what wood to use? Shamus Building & Construction 7 05-31-2008 01:29 PM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 10:33 PM
