Prep And Paint - Painting - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 08:26 PM   #1
prep and paint
I have a red wood sideing house that is pealing and have exposed wood. I woud like the best white hi glosse piant
teddybubba is offline   Reply With Quote
Old 04-22-2013, 08:41 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Bubba- you have a couple of big problems. Might require a good professional.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
chrisn (04-23-2013), jsheridan (04-23-2013)
Old 04-23-2013, 01:30 AM   #3
Too Short? Cut it Again!
Might think about a solid stain like SW Woodscapes on redwood. Why are you aiming for a high gloss finish on an exterior?
Old 04-23-2013, 03:57 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 390
teddy, wanting to know what the "best" paint is, is the least of your problems
Old 04-23-2013, 03:58 AM   #5
chrisn's Avatar
Rewards Points: 390
full moon keep you awake?
Old 04-23-2013, 06:45 AM   #6
Gymschu's Avatar
Rewards Points: 832
Sounds like it is redwood that has already been painted? If so, be gentle with the scraping as it's very easy to damage redwood siding. Scrape and sand off as much of the old peeling paint that you can. Remove all dust and prime with an oil based primer..........redwood can "bleed" through some latex wood primers. Two topcoats of your favorite paint and you're done. Personally, I like SW's SuperPaint Satin. Not a big fan of HIGH GLOSS on wood siding that is beat up a bit. You might also consider the one coat coverage of SW's Duration. It is pricey and somewhat overrated IMO.
Old 04-23-2013, 08:00 AM   #7
Central building fire alarm went off and I could not get back to sleep.One of the negatives of highrise living.
Just thought a solid acrylic stain might be a better option than paint for this since it will go over exposed wood or previously painted. I too was concerned about the redwood bleeding through a primer. It is a soft wood and you can carve it up in hurry trying to scrape paint off of it. I have had great results with SW Woodscapes on wood siding. It is self-priming. You still have to get loose paint off and clean what remains though.
I don't understand the desire for gloss though. To achieve a gloss the OP is going to need a very nice, even, primer/underlay layer. Maybe something like Benjamin Moore Fresh Start-Alkyd?
The Following User Says Thank You to user1007 For This Useful Post:
chrisn (04-23-2013)
Old 04-23-2013, 08:16 AM   #8
Rewards Points: 394
A high gloss finish will show any imperfections, especially if there is damaged wood.
Will22 is offline   Reply With Quote
Old 04-23-2013, 04:51 PM   #9
chrisn's Avatar
Rewards Points: 390
no way
Old 04-23-2013, 05:13 PM   #10
Mr. Paint's Avatar
Teddy,
Do as recommended above, gently scrape/sand to remove any loose paint, remove sanding dust, and yes, spot-prime the bare redwood with an oil prime or tannin-blocking primer. If you want to even out the surface so it doesn't look like the surface of the moon, apply Peel-Bond primer. for which, follow this link:
http://ximproducts.com/upload/pdfs/P...026%202012.pdf
It must be top-coated with an acrylic. This is a very useful undercoat if you are using a higher-sheen product.
The Painter's Paint Store where QUALITY is ECONOMY
Mr. Paint is offline   Reply With Quote
Old 04-23-2013, 07:33 PM   #11
Gymschu's Avatar
Rewards Points: 832
no way
Chris, do you ever agree with anyone? Sheesh. If you read the rest of what I said, I stated that it is OVERRATED. It is a consideration if you don't want to apply 2 coats. One coat is easier for the DIYer IN SOME INSTANCES.
Old 04-24-2013, 02:46 AM   #12
chrisn's Avatar
Rewards Points: 390
absolutely, when they are right. IN SOME INSTANCES
Old 04-24-2013, 06:27 AM   #13
Gymschu's Avatar
Rewards Points: 832
Old 04-24-2013, 07:09 PM   #14
Rewards Points: 5,974
Originally Posted by Mr. Paint View Post
Teddy,
I have been reading up on this primer but have not used it yet. From your post I assume you have. Would you share the results.
Paint coming off with delicate painter's tape, same prep as before... 7.62 Painting 8 03-16-2013 03:57 AM
Best way to prep and paint stained trim white ShelleyJ Painting 11 06-23-2012 09:32 AM
Chipping latex paint on masonite prep question Brettjones Painting 1 10-17-2011 05:26 PM
Please help with paint prep RinSF Painting 1 09-21-2010 06:07 AM
Questions about paint prep for exterior cedar siding. 240sx4u Painting 4 09-22-2008 10:46 PM
