Prep After Getting Trim Up - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 04:21 PM   #16
paper hanger and painter
chrisn's Avatar
Rewards Points: 300
Originally Posted by jsheridan View Post
This is a regular back and forth routine.
Jon, I'll second the use of spackle for holes, after priming if bare wood. I use lightweight vinyl spackle, not vinyl spackle, but lvs. Overfill the holes and sand, you're killing two birds, doing the normal after priming sand and smoothing the spackle. Caulk all joints. The problem with using spackle in joints is that it cracks in time. Do the best you can with the caulk to mask imperfect joints. As to caulk, I've never had much luck with Alex brand, just MO. I use one of the paint cos line of siliconized blends, not silicone, siliconized. I stay away from "painters" caulk.
Clown Free, At Last huh?
chrisn is online now   Reply With Quote
Old 02-08-2012, 06:19 PM   #17
Yes, I fell under the spell of that evil clown master--Sdsester. And then Matt1970 succumbed as well. However, I've broken free. Sds has taken his evil clown avatar down as well, but that's just a front.
Old 02-09-2012, 03:10 AM   #18
chrisn's Avatar
Rewards Points: 300
aahh, got it
Old 02-14-2012, 07:44 AM   #19
self help
Since this trim is s4s can I paint it with a small roller or should I use a angled sash?
Looking at SW Snowbound as trim color. Thanks
bigjon is offline   Reply With Quote
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 10:32 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 01:19 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Easier way to prep old painted trim? t yearian Painting 9 11-28-2006 03:21 AM
