Precautions-Scraping Paint Off Of Cement Porch-Help With Safety Issues - Painting - DIY Chatroom Home Improvement Forum
Old 04-01-2008, 05:59 PM   #1
Precautions-Scraping Paint off of Cement Porch-Help with Safety Issues
Quick question. I have the next couple of days off and am going to paint my grandmothers porch..never painted anything before..my grandma doesn't really care as long as its covered with something..The situation is the porch was painted..then there was a carpet over it for about 20 years..then the carpet got really raggity and we had to rip it off..underneath is some cracking paint..The porch is outdoors
I tested the paint for lead-there is no lead in the paint so that is not a concern. However, I am concerned about silica. No one knows what kind of paint was used. My grandfather has been dead for about 10 years..and my dad helped him, but he cant' rememeber what kind of paint was used either-it was painted around 25 years ago.
What kind of precautions should I take?
Should I be concerned about silica if I am scraping outdoors?
Would I need to get a full respirator to scrape the paint?
Any assistance would be appreciated..
Jim
jamesrwrightiii is offline   Reply With Quote
Old 04-01-2008, 10:02 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Although silica should not be taken lightly, in reality the silica warnings you see are because in extreme cases it can cause disease
Truly, we are talking about sandblasters, quarrymen, and miners
But...that doesn't mean full care shouldn't be taken when sanding
(sanding anything actually, as sandpaper has silica)
I like a good quality respirator when scraping and or sanding myself
slickshift is offline   Reply With Quote
Old 04-01-2008, 10:45 PM   #3
DIY Expert in Training!
That mask may be overkill but I used a 3M 6200 for my basement floor (asbestos). Get a P100 mask that fits well. Don't get it wet or it won't work. If you are doing a lot of work change after 6-8 hours or when it's really dirty.
Yes, I sell Safety Equipment.
gone_fishing is offline   Reply With Quote
Old 04-02-2008, 04:51 AM   #4
A Good Quality mask is not very effective if the wearer has a beard.Food for thought..................
mark942 is offline   Reply With Quote
Old 04-03-2008, 06:08 PM   #5
mark..agreed...I have seen guys drill holes for cigarettes and cigars so they can smoke when they work...that defeats the purpose just a little.
Old 04-04-2008, 02:41 AM   #6
wfischer's Avatar
OUCH!
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape!
wfischer is offline   Reply With Quote
Old 04-04-2008, 05:33 PM   #7
slickshift's Avatar
Originally Posted by wfischer View Post
OUCH!
What...you don't scrape and sand yourself?
Old 04-04-2008, 08:48 PM   #8
wfischer's Avatar
Hmm, I suppose I've scraped things off myself (paint, primer, glue). Sanding though? No thanks.
Old 04-04-2008, 10:16 PM   #9
slickshift's Avatar
Careful application of a belt sander can do wonders for that callous on your foot there....
Cement, plaster, paint - ceiling: "spray skim coat"? BradG Painting 1 11-18-2007 07:06 PM
cement porch retaining water jerry1967 Building & Construction 1 11-12-2007 04:49 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 06:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
