Powdery Look On Paint Finish - Painting - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 10:10 PM   #1
powdery look on paint finish
why has full gloss doors over time have a powdery feel to them
07dudlie is offline   Reply With Quote
Old 04-24-2012, 11:47 PM   #2
Rewards Points: 13,446
Ok what is it, and where is it you painted?
Old 04-25-2012, 08:27 AM   #3
Too Short? Cut it Again!
If it is oil based finish the paint is aging. "Chalking" is characteristic of oil finishes over time.
Harsh detergents can also cause the effect you describe. A rinse with a weak acid (add some vinegar to rinse water) MAY help.
Finally, the paint film may just be degrading. If it is vinyl and not acrylic it will dull just like your car interior.
How long since you painted? Is it time again?
The Following User Says Thank You to user1007 For This Useful Post:
Gymschu (04-26-2012)
Old 04-26-2012, 07:58 AM   #4
Gymschu's Avatar
Rewards Points: 652
Sdsester is on it again! I agree with the chalky observation. Old oil-based paint is notorious for chalking up after 7 or 8 years, even sooner if exposed to direct sunlight. You could wipe them down with warm water and a mild detergent to see how well they clean up. Some chalky surfaces clean up well and look as good as the day the paint was applied. If they don't look so good at least you have them prepped for the next paint job.
NEW DRYWALL, new addition, Need Primer chipraynor Painting 50 11-09-2011 11:45 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
