Old 10-02-2010, 11:26 AM   #1
homeowner learning quick
Powder room refresh/ painting -- toilet tank question
I am going to refresh our small powder room (6'L x 3'W) (new vanity, sink, faucet, lighting, & paint). The toilet is about 3/4 to 1 inch from the wall and will be difficult (probably impossible) to get behind to paint the wall. Is it safe to assume I need to shut off the water and disconnect the tank from the bowl before I paint? I can't seem to figure out any other way to paint the wall behind the tank without disconnecting it.
Sorry if this is an obvious question - I just want to make sure I'm doing it right the first time.
Thanks in advance
J
whataboutj is offline   Reply With Quote
Old 10-02-2010, 11:43 AM   #2
Matthewt1970's Avatar
You can do one of two things. Remove the lid and paint as far back as you can with a brush. Now stand back and see if you can see any unpainted surface. Odds are that is the way it was painted originally.
Second option is a wizzie/cigar roller. That will usually get back behind there.
Old 10-02-2010, 01:27 PM   #3
Thanks for the reply. I did look behind the tank and whoever did the last paint job definitely just removed the lid and painted behind it -- they actually did a terrible job getting behind it and I still couldn't tell until I got right up to it. That is definitely how I will do it. Thanks again
J
Leaking from toilet tank? tripflex Plumbing 4 09-29-2009 12:29 PM
Plumber's Question..about Toilet drain K.M.G Plumbing 4 09-23-2009 03:06 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Powder Room Framing Question Not Sure Building & Construction 9 08-11-2006 07:13 AM
question about cleaning a boiler room Piratehart General Discussion 1 02-14-2006 01:58 PM
