Old 07-21-2012, 02:49 PM   #1
Poured Concrete foundation basement walls--paint?
I have house, with pour concert foundation basement walls.
Plus 15 years in years.
I would like to paint the concert walls white but in not sure what brand or
type of paint would work best.
The house is in Vermont, and there has be no water problems since the
house was built. I just want brighten up the basement.
Also, do people often paint the bare wood of there open ceiling floor joists basement ceiling?
Thank!
Ranger2001 is offline   Reply With Quote
Old 07-22-2012, 10:04 AM   #2
Would you like to proofread you post before posting it?
TRUEPRO is offline   Reply With Quote
Old 07-25-2012, 10:11 AM   #3
Thanks, TRUEPRO
Old 07-25-2012, 10:37 AM   #4
Super Moderator
Call a local paint store and ask what paint would be best for your 15 year old basement walls---
There are some good concrete paints,but you will not find them at a big store like The Home Depot.
As to painting the bottom of your floor joists---it's done all the time---rent a paint pump for that job--Your local paint store rents them---Messy job--so cover the floors well---paint the joists first--then the walls--so you don't mess up the walls--
Old 07-25-2012, 10:39 AM   #5
Super Moderator
Moved this to 'painting' for you---
Old 07-25-2012, 11:04 AM   #6
Thanks, oh'mike.
The word is concrete to all others.
Old 07-25-2012, 11:10 AM   #7
Super Moderator
Fixed the title for you---
Old 07-25-2012, 05:39 PM   #8
paper hanger and painter
chrisn's Avatar
Usually a Block Filler is used first and then you can put on any paint you want.
chrisn is online now   Reply With Quote
Old 07-25-2012, 06:24 PM   #9
sdsester's Avatar
And you? Those that live in glass houses should not throw rocks.
sdsester is offline   Reply With Quote
The Following 2 Users Say Thank You to sdsester For This Useful Post:
kwikfishron (07-25-2012), ltd (07-25-2012)
Old 07-25-2012, 06:31 PM   #10
sdsester's Avatar
And they are stinky and usually alcohol based so make sure you have plenty of ventilation and wear an aspirator with the appropriate cartridge. They are also thick so you will need a four inch brush and fat roller cover. Your wrists will get a work out.
You should etch off any effluence on the surface of the concrete and clean and prep thoroughly before you start. Ask the paint store for a rec to match your situation.
Ditto on spraying the open wood framing in the ceiling. You will need to seal and prime it like any paint job. Then apply two coats. I would use a flat or low sheen paint.
I know some who have had luck cheating and using something like Sherwin Williams Woodscapes Acrylic Solid Stain. It is an exterior product but requires no priming. You can get it mixed to any color.
Old 07-25-2012, 08:57 PM   #11
Thanks, sdsester. for your most useful post.
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
painting basement concrete walls ctkeebler Building & Construction 6 11-17-2009 04:23 PM
Insulation for Concrete Basement Walls soundman79 Building & Construction 8 07-15-2009 02:54 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
