Is It Possible To Stain These Birch Kitchen Cabinets Dark Brown? - Painting - DIY Chatroom Home Improvement Forum
Old 08-07-2014, 10:04 PM   #1
Rewards Points: 95
Is it possible to stain these birch kitchen cabinets dark brown?
I'm in the process of remodeling my first home (a small condo), and it has the generic birch cabinets you see if all the apartments around here. They're in very good condition, and I'd like to know if it'd be possible to stain them a dark brown. If so, what does the process entail? Doing it myself, how long do you think it would take, and what would you estimate the supplies would cost?
Joe Link is offline   Reply With Quote
Old 08-07-2014, 10:17 PM   #2
Rewards Points: 402
Your best bet in my opinion would be to replace the doors and drawer fronts and reface the frames. Re staining the existing cabinets could turn out ok, or could be disastrous. Unless you are going to sand down everything and stain it. If you are thinking of putting some kind of stain over the top of those cabinets there are lots of things to consider. Depending on the type of finish they currently have, if you were to put another stain or poly over the top, the two could react and turn into a bubbly soft mess. There's really no way to tell what could happen. Refacing would be your best bet. You can go to refacedepot.com and price out your doors, drawer fronts and supplies all online.
taylorjm is offline   Reply With Quote
Old 08-07-2014, 10:54 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,286
Would you consider painting....
Espresso/java brown is a very popular color around here..... spraying obviously is your best option.... but "transformations" has decent leveling if you decide to brush.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Gymschu (08-09-2014)
Old 08-07-2014, 10:59 PM   #4
Rewards Points: 95
Not sure what the opinion of Ikea stuff is here, but if I were to spend the money to do that, I'd likely just replace everything. I was hoping with a color change and some nice pulls I could transform the look for a fairly low amount of money
I've never considered it, but if that's a professional option, absolutely. I really hate the look of brushed paint, seems you can always see the brush strokes. I'm painting the entire condo and replacing the floors, so would spraying be an option for me?
Old 08-07-2014, 11:06 PM   #5
Sure.... Condo's empty....
Old 08-07-2014, 11:07 PM   #6
Rewards Points: 95
You have a ballpark of what that costs? I'll be looking into it for sure
Old 08-09-2014, 08:22 AM   #7
Gymschu's Avatar
Rewards Points: 930
About $75 per gallon at Lowe's:
Not sure what someone would charge in your area to do the spraying. A spray unit can be rented by the day at your local paint/rental store.
Old 08-09-2014, 08:36 AM   #8
Rewards Points: 5,974
Have to ask since Ikea Has been known as swedish for particle board. Are you sure they are wood? Not particle board with a contact paper like product bonded to it. I have been told they now have real wood cabinets but if these are older they could be the PB.
If they are the particle board type you can't stain them. You can paint them but you will need a really good bonding primer. Sometimes it is hard to tell these cabinets apart.
Old 08-09-2014, 09:13 AM   #9
Jmayspaint's Avatar
Rewards Points: 534
If they are real wood with a lacquered finish, they could be toned. Cabinet finishers, and some painters can spray toned lacquer right over the existing finish, giving the cabinets an even stained look. A lot of modern furniture is toned that way.
Toning is probably not a DIY job. It takes some real skill with the sprayer to get a nice even job. A cabinet shop in your area might offer that service.
Jmayspaint is online now   Reply With Quote
Old 08-09-2014, 09:13 AM   #10
Rewards Points: 95
I looked at that stuff at Home Depot yesterday, but all I saw was the kit to turn dark cabinets light. It's possible they were out of the kit I'd need.
The cabinets I have aren't Ikea. I was saying that for the cost of new wood fronts, I'd likely replace everything with Ikea
The Following User Says Thank You to Joe Link For This Useful Post:
ToolSeeker (08-09-2014)
Old 08-10-2014, 10:05 AM   #11
Rewards Points: 236
look at all building supply stores (not home depot, lowes, etc) in your area. completely replacing them could be affordable for you. you will get a much better result. AND you would know exacctly what you are getting.
Fix'n it is offline   Reply With Quote
Old 08-10-2014, 08:29 PM   #12
Rewards Points: 95
Thanks, that's probably the way to go.
Tiles before or after kitchen cabinets? nipab Remodeling 9 01-05-2015 11:19 AM
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 13 03-02-2012 07:54 PM
staining birch kitchen cabinets Amy01 Painting 1 09-28-2010 11:01 AM
lay travertine floor or install kitchen cabinets first? palacenil Flooring 31 07-28-2010 10:42 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
