Possible To Spot Prime Cured Plaster? - Painting - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 08:57 PM   #1
Possible to spot prime cured plaster?
I bought a house in August which was built in 1929 and has plaster walls. I had plaster work done in late October in a guest room (mostly to fix cracks, but some water damage) and I'm finally getting around to painting it.
I went to Duron Paints for a primer and they recommended Terminator Stain Killer 2 which is water-based (and it's white, not tinted). Can I spot prime the areas that were re-plastered? Or does it make more sense to apply the primer to all the walls?
The original walls were painted a light beige and I plan to paint it a light green (which is only slightly darker than the current color). Will spot priming over the plaster work cause "flashing" of the topcoat?
Thanks in advance,
Neil
Neil H is offline   Reply With Quote
Old 03-04-2012, 09:06 PM   #2
Rewards Points: 13,458
When it comes to plaster walls I like to use oil based primer not latex.
Reason being I've seen plaster do some funky things, brown stains running down the wall, white spots flashing through ect.
Once the primer is dry you can go over it with ever paint you want.
Old 03-04-2012, 09:11 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Yes you can- but a couple of questions- if the walls were patched, chances are they used modern taping compounds, either dry and/ or premixed . It does happen, but rare that someone would use limed plaster.
Do you know what they used?
What you want to do now is get even porosity on your walls. Depending on what sheen you are going to, it would make sense to spot prime the patches and then do an overall prime, at least to the wall(s) that the patch was on. If you are going to a flat, not so much of a concern.
Expect 2 top coats.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-04-2012, 09:12 PM   #4
@joecaption: Are you suggesting I can spot prime with an oil-based primer?
Old 03-04-2012, 09:13 PM   #5
And joe- the funky things you saw were not from the cured plaster, they would be from glue no PASTE or contaminates on the wall. Cured plaster does not stain.
(forum joke..)
Old 03-04-2012, 09:14 PM   #6
That is what joe said. I do this with acrylics all the time.
Old 03-04-2012, 09:15 PM   #7
@BrushJockey: I don't know what was in the plaster. But I'm planning on using a flat paint. That said, you think I can use two topcoats after spot-priming?
Old 03-04-2012, 09:18 PM   #8
Sure. If you see anything weird ( I don't expect you will) come through the prime come back and tell us about it before finishing.
Old 03-04-2012, 09:54 PM   #9
Oh- Caught the water damage part- if the patches have a sign of brownness bleeding through, then i would agree with joe about the oil. The waterbase stuff you have "might " do it, but a water stain is best kept back by something that isn't waterbased.
Technology is changing fast on this , so there are exceptions. Not familiar with that product.
If you already have it- try it. And even if it bleeds a little, let it dry well and reprime the stain.
Sometimes you can "trap"the stain in the first coat and seal it with the second.
If that doesn't work, use oil on the stain itself, otherwise prime as before.
The Following User Says Thank You to Brushjockey For This Useful Post:
Neil H (03-04-2012)
Old 03-05-2012, 04:11 AM   #10
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
(forum joke..)
I am keeping my eyes open
chrisn is online now   Reply With Quote
Tags
paint , plaster , primer , walls
tile directly on bare veneer plaster? bubbler Kitchen & Bath Remodeling 6 03-03-2011 08:29 PM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
what to spot prime after scraping? tomcon Painting 1 07-21-2009 03:50 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
Spot Priming or prime everything? hdtvluvr Painting 2 09-30-2007 07:32 PM
