Possible Lead Paint On Doors - Painting - DIY Chatroom Home Improvement Forum
Old 03-28-2008, 09:34 PM   #1
Possible Lead Paint on Doors
I want to sand some doors that could possibly have lead paint. There are so many layers of paint on the doors that they have a hard time closing and opening, so I want to sand the old paint off and put a new layer. I plan on taking the doors down and sanding them outside. My question is, is that safe to do? What would be the safest way of doing this. We're talking about 6 doors here. Any suggestions would be greatly appreciated.
-Dank
dankreboot is offline   Reply With Quote
Old 03-29-2008, 04:56 AM   #2
Layers of Paint
mark942 is offline   Reply With Quote
Old 03-29-2008, 05:54 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
No, it is absolutely not safe to sand, scrape, media blast, use methylene chloride, propane torch or heat gun that operates over 700* F on these doors
slickshift is offline   Reply With Quote
Old 03-29-2008, 07:29 AM   #4
Rewards Points: 506
Unless you are really attached to these old doors, I'd just take them down and have a carpenter attach new ones. Either that, or send them off to maybe a furniture stripper and have him remove all the old finish.
I would be hesitant to DIY any of this, even outside.
SirWired
sirwired is offline   Reply With Quote
Old 04-12-2008, 07:34 PM   #5
SirWired
What is the harm if I do it outside and wear a painters mask? I don't understand. Please adivse!! I really want to save money and I believe they are the original doors. If there is a huge health risk than I won't do it, but if there is a way to be safe I don't understand why doing it outside is risky...
Old 04-13-2008, 07:32 AM   #6
slickshift's Avatar
Lead Poisoning
Because the lead dust causes brain damage
The dust outside will blow into your yard, your shrubs, and your ground, your neighbor's pool, and their topsoil
They can then have their soil and pool water tested, and if lead is found, you will be responsible for the Haz-Mat clean-up of their yard, including all new shrubs and replacement of their topsoil (a few inches to a foot depending), and possibly a Haz-Mat clean-up of the inside of their house
This will easily cost tens of thousands of dollars
Never mind the fact that you also contaminated your yard, and should really do a Haz-Mat clean-up on that too
That is if you don't want to have lead poisoning
Old 04-13-2008, 07:33 AM   #7
slickshift's Avatar
Remove them, and bring them to a stripper
Old 04-19-2008, 07:27 PM   #8
lead paint remover
DO NOT sand! Try Multi-strip -- you brush it on with a paint brush, let it bubble up and then scrape it off. Lots of work to get all the nooks and crannies done, but it's not as toxic as the old chemical paint strippers. The smell is awful, but otherwise it's not bad. Set up the doors in a garage or basement and put plastic underneath, along with layers of newspaper, as the paint will drip off. Go to a paint store and they can advise you.
Here's a link to more info on dealing with lead hazards. Good luck!
http://www.oldhouseweb.com/stories/Detailed/280.shtml
Allison1888 is offline   Reply With Quote
Old 04-20-2008, 04:54 AM   #9
Rewards Points: 506
I wouldn't strip either without calling the local health department. If you strip lead-painted doors, now you have plastic and newspaper full of hazardous waste, not to mention whatever spattered or scattered during the process all over your clothing and skin.
SirWired
paint coming of from doors and frames np2008 Painting 6 03-06-2008 06:03 PM
Paint chipping on trim and doors. RR33 Painting 9 12-30-2007 07:26 PM
lead based paint detectors samf Painting 1 03-20-2007 08:24 PM
lead paint - remove or cover? teresa17603 Painting 8 10-26-2006 06:14 PM
Stripping old paint off interior doors ? Scott_K Painting 9 05-12-2005 09:05 AM
